Burn out question.
Old Apr 26, 2005 | 04:08 PM
Jigs's Avatar
Ok so ive been doing burn outs lately.
And i've noticed that when i burn out. Only one of my tires spin.
The right tire spins, but the left one doesnt.
Heres how i do my burn outs on auto.
Method 1.
I put it on drive, and hold the break, and press the gas pedal at the same time.
Method 2.
I put it on '1', hold the break, and press gas.
But it seems that my right rear tire is the only one spinning.
The left spins sometimes, but it doesnt go all the way like the one on the right.
Is it suppose to do that? or is there something wrong??
Tips please !
Old Apr 26, 2005 | 04:16 PM
jsheehan's Avatar
The reason on;y one tire spins is because you don't have a limited-slip diferential in your rear end. The differential in the V6 locks, so power only goes to one wheel, the one with least resistance. If you put a T-lok (a limited slip diferential, which comes on the GT), power will be distributed evenly to both wheels.
Old Apr 26, 2005 | 04:35 PM
stupidgenius36's Avatar
Just Plain Rude!
Once the power is divided between the two wheels, will it make it significantly more difficult to do a good burnout?
Old Apr 26, 2005 | 04:39 PM
jsheehan's Avatar
Well, you will certainly get better traction off the line, which would make it harder. However, I am sure you will still have more than enough power to light the tires up.
Old Apr 26, 2005 | 05:59 PM
Mustang05's Avatar
I can do a good burn out with BOTH wheels it i hold rpms as 2000!
GTPETE
Oct 12, 2015 02:20 PM
50Cal
Sep 16, 2015 03:54 PM
Hristofor
1994-2004 V-6
Sep 11, 2015 12:05 PM
