aluminum driveshaft & safety loop
Old Aug 14, 2011 | 09:28 AM
thunderbolt's Avatar
Hi all. I recently had installed a 4" aluminum driveshaft on my '06 4.0 auto
this was to combat my stock driveshaft that was vibrating like crzy after a rear end gear change
ok, so drivehaft is 4" Shaftmaster unit and I'm quite pleased with it
The safety loop is another issue. I got one from BMR and it seems its too tight around shaft so does not allow for any travel and as such causes rubbing / grinding. have tried (with tech) to adjust loop but still rubs.
what loop are you guys with aluminum shafts using? any tips appreciated.
Old Aug 14, 2011 | 02:36 PM
karman's Avatar
No Tips...Questions
Why do you need a loop, are you supercharged?
Was everything marked during the gear swap and put back in the same place?
Did you try other orientations for the stock driveshaft before you gave up?
I am curious if one was better than another.
Old Sep 25, 2011 | 10:56 AM
amustangrocks's Avatar
might want to give shaftmasters a call and see what they suggest going with for a loop. ive been putting this swap off for my u joints to get weak. i`m getting up in miles now so i imagine pretty soon i`ll do it. the loop is a good idea to have whether your sc or not after spending the cash on the shaft. good choice on the shaft, i might look into the 3.5" too.
is your loop 2 pc`s? could you put some spacers in it to open it up a little? just a idea
Old Oct 1, 2011 | 06:51 PM
JimC's Avatar
legacy Tms Member
I have the CHE loop on my car and it clears the 4" Shaftmasters with no issues at all.
Mar 30, 2021 09:29 AM
dblhelx
Oct 6, 2015 08:08 PM
Evil_Capri
Sep 24, 2015 04:30 AM
tbear853
Sep 8, 2015 11:18 PM
