05 V6 inexpensive shorty headers
Old Sep 18, 2009 | 08:03 PM
amustangrocks's Avatar
if your on a tight budget but would like to upgrade those rusty cast iron manifolds, check out ebay. i got a set of stainless shortys on a bid from eworld1 sales for 114.00 shipped. theres a bunch of places selling generic headers on there. they sure look good, even after the color change, have better flow than the cast and weight about 20 lbs less. the install is not bad,90% from the top, i found it easier to do the cat flange bolts from the under the car. something for a saturday afternoon project.get the plug wires out of the way and remove the cast irons. remove both side flange bolt nuts and you can wiggle the cast irons out. even though the headers came with new bolts, i used the factory studs that are in the heads instead of removing them and nuts. depending which ones you get, there might be a couple studs that need the tip cut off for clearance of the tubes. i didnt have to cut any. the studs dont rust but the nuts do and can be replaced with stainless nuts. remove the oil distick bolt, then the tube by pulling it up and out. there are a couple brackets on the pass side to remove, and the coil bracket will have to be bent just a little because of the 3/8" flange thickness. i had to buy a longer bolt for the dipstick tube. after you run them, they turn gold for a bit, then the blue,purple,red look. they sure make the engine bay look better, add a little sound to the exhaust system, and i think a bit of performance.
Attached Thumbnails 05 V6 inexpensive shorty headers-headers1.jpg   05 V6 inexpensive shorty headers-header-colors.jpg
Old Sep 22, 2009 | 08:33 PM
retro_pony's Avatar
You make a valid point, they look worlds better than our rusty ones!
Old Oct 1, 2009 | 05:53 PM
ya, i have over 5k on them, no problems, no regrets.
Old Oct 20, 2009 | 09:10 PM
Tungsten Bullitt's Avatar
I'm having trouble with my drivers side header. I can't get the EGR tube loose!!
Old Nov 9, 2009 | 10:50 AM
I got mine installed now. Great mod!
A Big Thanks to amustangrocks for your advice.
you can sure tell the difference...
Old Nov 9, 2009 | 11:16 AM
slowjoe24's Avatar
Good info guys!! I had planned to do the JBA set, but now I'm not sure........anybody running those??
wallace
Mar 29, 2016 10:09 AM
cameron2581
'10-14 Interior and Audio
Nov 26, 2015 01:26 PM
FromZto5
Sep 30, 2015 05:28 AM
billy y
Sep 24, 2015 11:48 AM
Stephen Laslo
V6
Sep 18, 2015 07:57 PM
