05-08 4.0 V6 Tremec TR3650 / TR6060 Adapter
Originally developed for my personal 2006 V6 Mustang this kit is now available to everyone that is tired of the 2005 - 2008 V6 Mustangs poor quality stock T5 5-Speed manual transmission. Designed to work with the Tremec TR3650 5-Speed found in 2005 - 2008 Mustang GT or the Tremec TR6060 6-Speed found in the 2007 - 2008 Shelby GT500. Both of these transmissions are far superior to the Tremec T5 supplied in the V6 Mustang. Offering silky smooth shifting and much more strength especially for those that have broken or keep on breaking the T5 do to having a supercharged or turbocharged engine.
The adapter is made from aircraft grade 6061T6 aluminum for light weight, high strength and lasting durability. Sleeves are produce from pre heat treated EDT-150 hardened steel. Fasteners are metric grade 10.9 high strength pieces.
If planning on converting to the TR6060 keep in mind that the deferential gears will need to be changed to 4:10 because the TR6060 is geared way to high for the V6 application. Installing 4:10s will give basically a stock first gear ratio and the next 5 gears will all be nice and close together. Also for the TR6060 application you will need to source a GT500 cross member and have a 26 spline clutch disk fabricated. These are also easily obtained through online sources. Addtionally a circuit for the reverse lockout solenoid must be wired in.
This kit contains everything required to bolt the TR3650 or TR6060 transmission to the 4.0 V6 engine block. Customers must supply their own transmission, shifter and aftermarket aluminum drive shaft readily available from a number of online sources. Installation is reasonably straight forward. The front O2 sensors must be relocated and the instruction manual explains how to do this. Also it may be necessary to do some very minor clearancing with a Dremel tool. Some customers have found that no clearancing was needed. Very minor wiring needs to be done to hook up the speedometer and reverse light pigtails. All of this is explained in the supplied comprehensive installation manual that includes photos, bolt locations and all torque and fill specifications.
I have had the TR6060 transmission in my own 2006 4.0 V6 Mustang for over 20,000 miles with no issues at all. This includes plenty of trips to open road course days and autocross events.
PM me with any questions.
Long tubes and tr3650
I know this is an old thread but, I'm running pacesetter long tube headers on my 4.0... are there any known current tr3650 swaps with these headers? I'm worried about clearance issues between them and the trans if I go through with the swap.
I have not installed the adapter using long tubes and don't know of any that have. That being plenty of guys including myself have installed it with shorties. The shorties get real close to the transmission housing were they couple to the cats. Since long tubes don't have this coupling in that position I would think they may actually have better clearance. I would take a look at a stock V6 setup to see what the clearance looks like in that area. If the long tubes are a lot closer that may be an issue. Good luck.
Thank You For Taking The Time To Reply!
Here is CeskZ's Situation. Perhaps You Have Some Input?
https://themustangsource.com/forums/...6-info-551442/
KC
KC
