Wrong Gear and Dyno
Old Dec 7, 2008 | 08:24 PM
puremike's Avatar
Wrong Gear and Dyno
Took the mustang to get a custom Dyno tune Saturday morning. I was pleased with the results, but on the way home I noticed the speedometer was 5-6 MPH off. Took a look and the tuner set the gear ratio to 3.31 when I actually have 3.55 in the car. I set the ratio to 3.55 and it corrected the discrepency with the speedometer. My question is, would this have affected the results on the dyno?
Old Dec 8, 2008 | 05:41 AM
I am not sure but would dobt it. What mods do you have?
Old Dec 8, 2008 | 07:34 AM
puremike's Avatar
Steeda CAI, Steeda Underdrive pullies,GMS 60,000 V Ignition Coils, BBK Throttle Body, 93 octane tune. Manual Transmission.
Old Dec 8, 2008 | 01:46 PM
puremike's Avatar
So I guess the questions is, does the dyno use what speed that the car thinks it is going to make its calculations?
Old Dec 8, 2008 | 02:00 PM
Black GT500's Avatar
No. The dyno doesn't care what your speedometer is reading.
Old Dec 8, 2008 | 05:42 PM
SlamMan02's Avatar
Bingo.
Old Dec 8, 2008 | 05:51 PM
70MACH1OWNER's Avatar
I agree the dyno does not know what gear your car has in it. Your results should be accurate. The speedometer means nothing. They just take it up to a max rpm that you told them to go too!
Old Dec 8, 2008 | 05:59 PM
ILikeBond's Avatar
Along the same lines - would leaving traction control on affect the dyno reading? Seems like it maybe could, right?
I took mine to the dyno this weekend and forgot to tell the guy to turn the dyno off. Now, he may well have known that - and it was a mustang specialty store - but they deal with older mustangs, mostly, and I would have felt better just reminding him anyhow, but I forgot. Stupid.
If it would/could affect the dyno result, by how much do you think? Would TCS have to engage (in which case, you'd probably know it).
Old Dec 9, 2008 | 02:09 AM
SlamMan02's Avatar
Doubtful T/C did anything to hinder your results unless it was engaged through wheel spin.
Old Dec 9, 2008 | 02:27 AM
2kanchoo's Avatar
.If it would/could affect the dyno result, by how much do you think? Would TCS have to engage (in which case, you'd probably know it).
when I took mine to a dynojet dyno I HAD to have the TC off or the car wouldn't get going. It wasn't the difference between a good run and a bad one. It made the difference of a good run, or no run.
Old Dec 9, 2008 | 04:01 PM
ILikeBond's Avatar
Cool, thx guys.
Road_Runner
Sep 2, 2024 04:46 PM
Rando
Aug 25, 2021 11:12 AM
trackpack13gt
Jul 25, 2017 05:29 PM
PonyMuscletang13
Sep 29, 2015 09:40 AM
