WOT A/F Ratio
WOT A/F Ratio
Hey guys what ratio is a safe or standard a/f at WOT? Also, on my sct tuner would there be any negative side effects to turning the fans down to start at a lower temperature?
Thanks,
Ben
Thanks,
Ben
Thanks,
Ben
Thanks,
Ben
Originally Posted by Firedude
Some engines are set up(tuned) to run best at a set temp. Sometimes its for emission reasons. I would talk to a good tuner. I use Doug at Bama.
That's why it shouldn't matter. A lower fan temp means the thermostat has cooler coolant available for it from the radiator. That just means the engine is less likely to go over the right temp, the thermostat will always keep it from going under temp.
CiniZter
25
4/28/16 05:41 PM
