Is It worth getting
Old May 24, 2005 | 07:59 AM
gotmy05's Avatar
I just got my tax return yesterday and I have been wanting to get the SLP Loudmouth exhaust, But before I order it I wanted to know what everyone who has it thinks about it. I love the sound. But I hear mixed feelings on the power...
Old May 24, 2005 | 08:03 AM
MaverickMLFD371's Avatar
IMO, i thought since there was no mufflers, no mufflers = no back pressure, back pressure loss = loss horsepower. I went under that assumption and switched to Flowmasters for the sound and performance.
Old May 24, 2005 | 08:17 AM
gotmy05's Avatar
i heard there was a performance loss on the flowmaster
Old May 24, 2005 | 08:32 AM
Mustang69-05's Avatar
All I have to say is that I LOVE mine!!!! Looks great and sounds even better!!!!
Old May 24, 2005 | 08:33 AM
Double post...... Stupid computer.......
Old May 24, 2005 | 08:42 AM
Cheese302's Avatar
actually there is little backpressure loss going through the mufflers. Most backpressure is caused by the tubing itself. This is due to the pressure head loss and the friction head loss caused by the walls of the tubing. Head loss is the pressure lost due to friction measured in length.
So if you use bernoulis equation you will find that because of the muffler having a lot more space inside it, it will actually cause less back pressure in the muffler than replacing it with straight pipe.
You probably thought that because the muffler causes it to be quieter, it causes more backpressure, where as in actuality the displacement of volume by the mufler is actually what cause the noise reduction. Also there in not adding much backpressure.
Now if you start running side exits, or cut the exhaust off at the h-pipe, that will cause less backpressure, becaus the length of tubing is reduced, also there is a huge increase in back pressure at the over axle pipes, due to the bends These are actually greater than the pressure from the cats.
So paul. need help putting the flowmasters on this weekend?
I thought i would throw some of the engineering knowledge i learned over the past 4 years into play
Old May 24, 2005 | 08:47 AM
05stangster's Avatar
Cheese302, I thought the Magnaflows offered more HP than flowmaster b/c the flowmaster has 2, 3 or 4 bends (tubes) - and the Magnaflow goes straight through the muffler. Atleast, when I put them on my truck that's what they looked like. Can you explain the difference b/t the two? As you can see, I do not have extensive engineering knowledge - just enough knowledge to f*** things up
Old May 24, 2005 | 08:48 AM
mrv8outboard's Avatar
SLP Loudmouths...
YES
YES
YES
Do it !
Old May 24, 2005 | 08:50 AM
there was a performance loss on those who got the Flowmasters because they forgot to reset their computer. When they finally reset the computer, then they noticed an def. increase. And Flowmaster tells you that you must reset the computer to recalibrate it to the new mufflers.
Old May 24, 2005 | 08:59 AM
gotmy05's Avatar
ahhhhhhhhh I see I see........
Old May 24, 2005 | 09:20 AM
ZRX4ME's Avatar
I Noticed a nice increase in performance/throttle responce when we put loud mouths on my wifes car(also hydrocarbon trap removed).It is reasonably quiet at idle,but roars at large throttle openings.My steeda exhaust is more deep-toned down low,but cant compete with her loudmouths at WOT.
Old May 24, 2005 | 09:23 AM
Mustang Kid's Avatar
I just got my slp's last night and had them on in less than an hour. They fit perfect, look awsome and sound wicked. Im very happy with them.
Old May 24, 2005 | 09:48 AM
stangscuba98a's Avatar
SLP
Old May 24, 2005 | 01:54 PM
gotmy05's Avatar
I Ordered them should have them in a week I hope sooner. Thanks for the coments. They are on their way. :headbang:
cameron2581
'10-14 Interior and Audio
Nov 26, 2015 01:26 PM
FromZto5
Sep 30, 2015 05:28 AM
TerryD
Sep 28, 2015 11:48 AM
Sep 8, 2015 10:45 AM
