Wheel spacers or steering stops?
Old May 21, 2007 | 05:11 AM
Louie's Avatar
As many of you know, Ford recommends the installation of steering stops when upgrading from 17x8" wheels to 18x8.5" or 18x9.5". I was wondering whether a similar effect (no rubbing of the tire against the wheel well, I presume) could be achieved by installing wheel spacers (I'm thinking 1" max).
Recently I started noticing a rubbing noise coming from the front left well when completely turning right. I checked the well lining and I can't see any marks anywhere. However, I'd like to widen the stance anyway, so installing the wheel spacers might solve two problems at once.
Any ideas?
Old May 21, 2007 | 12:06 PM
adrenalin's Avatar
I guess that all depends on the rim. I have 18x9 on the front and didn't use spacers or stops. Even when lowered the tires don't rub anywhere.
Old May 21, 2007 | 03:14 PM
Forge's Avatar
same, i run 18x9.5 all the way around, no spacers or stops and it never rubs. I run a steeda ultralite spring
Old May 21, 2007 | 07:47 PM
RobK's Avatar
+1 If the wheels are the correct offset you won't need spacers. I have 18x9s with no issues.
Old May 22, 2007 | 09:39 AM
kevinb120's Avatar
If the tires rub the wheel wells, wouldn't you just unsteer the car 1/4" The old cars were notorious for this, my brain was able to handle the situation just fine.
tdf017
Aug 5, 2015 10:13 AM
Wild5.0
'10-14 Exterior Modifications
15
Aug 4, 2015 11:22 PM
retiredf5
Ecoboost
Jul 21, 2015 05:54 PM
LuiG31
Ecoboost
Jul 20, 2015 01:25 PM
Vader99
Jul 19, 2015 08:19 PM
