What is the purpose of Steeda's G-Trac Brace?
Old Mar 3, 2007 | 09:28 AM
Jon_Purdy's Avatar
What is the purpose of Steeda's G-Trac Brace? Is it something I should have for a mainly street driven car?
Jon
Old Mar 3, 2007 | 09:34 AM
TillmanSpeed's Avatar
Former Vendor
That kit is intended to add strength between the LCA's or as they say it adds a "positive link". It's a great thing to have for a street car, but on the track is where you would feel the difference.
CR
Old Mar 3, 2007 | 09:49 AM
theedge67's Avatar
Would that potentially help with the 'wheel hop' issue?
Old Mar 3, 2007 | 11:29 AM
Mik's Avatar
Mik
The G-trac is for the front suspension. So no it won't help with wheel hop.
Old Mar 3, 2007 | 11:43 AM
thump_rrr's Avatar
Get a UCA for wheelhop.
Old Mar 3, 2007 | 12:03 PM
Former Vendor
Will not help with wheel hop, as stated above. If anything, it would be comparable to a front sway bar. Since the problem with wheel hop is transfer in the rear suspension, a good set of UCA's and full length subframe connectors will cure the wheel hop woes.
Old Mar 3, 2007 | 12:28 PM
thump_rrr's Avatar
S197's only have 1 UCA due to the 3 link suspension.
Also subframe connectors are not required with our cars.
Some people running 9's may see a slight difference but it's a rare mod on these cars.
Old Mar 3, 2007 | 12:53 PM
theedge67's Avatar
I answered my own question I had posted here a second ago...
Old Mar 3, 2007 | 03:23 PM
Red-06-GT's Avatar
Does anyone have a picture of one installed? Are there supposed to be bushings in the kit? I have one for install in the spring and I'm having trouble getting my head around the install. The kit comes with new nuts, bolts and washers. There seems to be quite a bit of play when the bolts are inserted in the tubes at the end of the brace. Seem like there will be noise after the install... Or maybe I just worry too much.
Old Mar 3, 2007 | 04:35 PM
Former Vendor
Yea, just used to saying set of UCA's.
For the subframe connectors, we've had GREAT luck with them on a few cars we've dealt with over the summer/fall with low 11 second time slips?
That was with the full length chromoly.
Old Mar 3, 2007 | 08:21 PM
Mik's Avatar
Mik
Check out Granatelli's site. Its called an A-arm Brace there.
Click on 'install' and you'll get pictures and an instuction guide. Easy install, just unbolt 2 bolts (one on each A-arm) and bolt the new brace in.
http://www.granatellimotorsports.com...a-armbrace.htm
Old Mar 4, 2007 | 07:24 AM
you can make one of those yourself very easy. If I remember corectly the hole centers are 21.5 inches. I made mine install was pretty easy
Old Dec 7, 2007 | 06:53 PM
metroplex's Avatar
So which brace is better:
CHE, Steeda, Granatelli, or BMR?
Old Dec 7, 2007 | 07:03 PM
Import-Slaya's Avatar
CHE--see my other post.
Feb 10, 2017 07:12 PM
Sep 30, 2015 07:02 PM
GeoWett
Sep 30, 2015 06:40 AM
Sep 24, 2015 08:15 PM
Sep 16, 2015 06:44 PM
