What does engine knocking sound like?
Old Sep 30, 2005 | 06:33 PM
dustindu4's Avatar
9 is not my lucky number.
I made the switch to 93 octane and did the diablo tune while I was filling up. As I pulled out of the station there was this awful rattling sound comming from the engine. I immediately pulled over and reflashed to 91 octane and still had some mild knocking but not bad so I pulled over again and flashed to 87 and it went away.
Then it hits me like a ton of bricks that when I filled up I only put 13 gallons in so there was 3 gallons of 87 in there, PLUS I didn't let the gas lines bleed out of the 87, duh.
I think I'll burn through half a tank tomorrow and fill it up again and try the 93 tune again.
Old Sep 30, 2005 | 06:40 PM
6505pony's Avatar
Run the 91 tune for the first tank of 93 gas you put in. Then flash to the 93 when you run out most of the tank you just put in and refill to 93 again.
This way everything gets good and flushed.
I just wouldn't push it hard until your on your second tank.
Your other would be do as you say run the tank half down the way you are but don't flash to 93 just 91 until that is gone. Then 93 when you refill.
Old Oct 1, 2005 | 12:03 AM
dustindu4's Avatar
Okay that sounds like a good plan.
Old Oct 1, 2005 | 02:06 AM
Mongoose's Avatar
Sounds like hammers banging inside your motor. NOT GOOD
Old Oct 1, 2005 | 07:41 PM
dustindu4's Avatar
I filled up on 93 again today and the knocking went away, thanks Steve
05GT4.6
Sep 7, 2015 11:06 PM
GTown3r
1994-2004 V-8
Aug 30, 2015 08:04 AM
Evil_Capri
Aug 27, 2015 01:08 PM
JonsMustang
Aug 10, 2015 05:03 PM
EaterofWorlds
Aug 9, 2015 06:01 PM
