What are the disadvantages of lca's w/rod ends?
What are the disadvantages of lca's w/rod ends? I ask because what I've been reading about bushings failing is a bit of a concern. Just curious.
Jon
Jon
Road noise is transmitted directly to the body. Suspension movement is more precise, but that comes with suspension harshness (no give).
yeah, the only thing i am getting with rod ends is the pan hard bar because i have to with the BMR relocation bracket, but what stops road noice is the bushings, whithout them road noise is noticable
I, personally, have not heard of a CHE bushing fail yet (though I'm sure it has happened and I'm sure it is possible), but I have heard of the Steeda and BMR's failing, a lot.
I had the BMR lowers, and though they didn't fail, they were loud and noisy (poly ends too). The Steeda's are MUCH quiter, but I've heard people popping bushings on launch (repeatedly) with the Steedas, but on the street they work great and really quite.
I'm going with all CHE stuff, allready got the panhard bar on, and have the UCA, LCA's, Anti squat brackets, and K-member brace with torque limiters going on next. Lots of good feedback from other users.
steeda and BMR's failed because peopel greased them too much or didnt use the grease BMR sold and used marine grease or some other type. you need the engergy suspension grease BMR sells for the bushings. it is thick, white, and feels like glue. also dont use the grease fittings to grease the components. take the bushings out of the piece prior to installation and using a brush coat the bushings with a thin layer of the grease. this will ensure your bushings dont split or break
Personally, I would leave the Heim joints pieces for "race only" applications. I've rarely seen them stand up long term to the rigors of a street driven car, even when they are just used in swaybar links.
Racers normally keep a very watchful eye for wear on all their suspension pieces, most street cars don't get that kind of attention.
JMHO
JMHO
The bushings in all brands of LCA's are made of the same materials.
I like the LCA BMR makes that has a poly on one end and solid on the other (the end that people tend to split with poly).
I hadn't given CHE much thought until your post Hatchman. What impressed me is their more detailed installation instructions. Whilst BMR's are good, CHE provided pictures for newbies like me.
Jon
Jon
+1 More NVH (Noise Vibrations Harshness), but they flex less and do there job better.
Yep, color pictures for each step are good for me, since I can't read so good.
