What are the disadvantages of lca's w/rod ends?
Old Jan 6, 2007 | 11:34 PM
Jon_Purdy's Avatar
What are the disadvantages of lca's w/rod ends? I ask because what I've been reading about bushings failing is a bit of a concern. Just curious.
Jon
Old Jan 6, 2007 | 11:48 PM
RadBOSS's Avatar
Jon
Road noise is transmitted directly to the body. Suspension movement is more precise, but that comes with suspension harshness (no give).
Old Jan 7, 2007 | 12:01 AM
RedDragon777's Avatar
yeah, the only thing i am getting with rod ends is the pan hard bar because i have to with the BMR relocation bracket, but what stops road noice is the bushings, whithout them road noise is noticable
Old Jan 7, 2007 | 06:08 AM
Hatchman's Avatar
Jon
+1 More NVH (Noise Vibrations Harshness), but they flex less and do there job better.
I, personally, have not heard of a CHE bushing fail yet (though I'm sure it has happened and I'm sure it is possible), but I have heard of the Steeda and BMR's failing, a lot.
I had the BMR lowers, and though they didn't fail, they were loud and noisy (poly ends too). The Steeda's are MUCH quiter, but I've heard people popping bushings on launch (repeatedly) with the Steedas, but on the street they work great and really quite.
I'm going with all CHE stuff, allready got the panhard bar on, and have the UCA, LCA's, Anti squat brackets, and K-member brace with torque limiters going on next. Lots of good feedback from other users.
Old Jan 7, 2007 | 07:53 AM
94tbird's Avatar
steeda and BMR's failed because peopel greased them too much or didnt use the grease BMR sold and used marine grease or some other type. you need the engergy suspension grease BMR sells for the bushings. it is thick, white, and feels like glue. also dont use the grease fittings to grease the components. take the bushings out of the piece prior to installation and using a brush coat the bushings with a thin layer of the grease. this will ensure your bushings dont split or break
Old Jan 7, 2007 | 10:24 AM
Jon_Purdy's Avatar
One more lca question, billet aluminum or tubular steel?
Old Jan 7, 2007 | 10:42 AM
LBJay's Avatar
Personally, I would leave the Heim joints pieces for "race only" applications. I've rarely seen them stand up long term to the rigors of a street driven car, even when they are just used in swaybar links.
Racers normally keep a very watchful eye for wear on all their suspension pieces, most street cars don't get that kind of attention.
JMHO
Old Jan 7, 2007 | 11:47 AM
billet aluminum has been proven stronger but only certian guages
Old Jan 7, 2007 | 11:58 AM
169stang's Avatar
The bushings in all brands of LCA's are made of the same materials.
I like the LCA BMR makes that has a poly on one end and solid on the other (the end that people tend to split with poly).
Old Jan 8, 2007 | 12:26 PM
Jon_Purdy's Avatar
I hadn't given CHE much thought until your post Hatchman. What impressed me is their more detailed installation instructions. Whilst BMR's are good, CHE provided pictures for newbies like me.
Jon
Old Jan 8, 2007 | 11:50 PM
Hatchman's Avatar
Jon
Yep, color pictures for each step are good for me, since I can't read so good.
Old Jan 8, 2007 | 11:59 PM
i like the BMR stuff, so what side do people tend to split, the connection to the axle or to the brace?
Old Jan 10, 2007 | 04:02 PM
Bump, anyone find out where the rod end usally splits
Old Jan 10, 2007 | 10:17 PM
theedge67's Avatar
Also, do the aftermarket LCA's require grease as a maintenance item at certain intervals, or are they greased for life at install??
robjh22
Dec 14, 2015 08:41 AM
GTPETE
Oct 12, 2015 02:20 PM
DrVet
Sep 23, 2015 01:48 PM
DEPUTY62
Sep 12, 2015 11:12 AM
1001yos
Sep 8, 2015 10:05 PM
