what the best tire psi w/ stock tires at track?
Originally posted by Mrericpm@May 31, 2005, 5:33 PM
i usually take them down to between 15 and 20... u said u have a better tune in ur sig.. what was ur first tune and who did it and same quetion on the second tune
elvism, My tuner told me that I should keep tire presure at about 28 and not to just punch the Auto from the line, but to ease into it. If you go too low it will hurt your time. He is the president of the Lighting club here so I will give his advice a try. I will try that the next time I head to the track to run the car. I had planned to go last Sunday night, but the weather here had other ideas.
Are you getting alot of wheel spin? Mine's not. I can get a long burn out if I want to but my traction off the line has been good. This thing really hooks up well.
Wish you luck on Thursday.
Steve
Steve
Mike, for me, and I've tried it at just about every tire psi, keeping it at stock psi (36) worked just as good, if not better, than any other. I was on stock rubber for awhile. I started testing at 30 and decreased by 5 psi. I saw no increase in 60' times so I went back to 30 and increased by 2 psi. You may want to ask bryanzstang. I believe he's cutting great 60' times, still on stock rubber.
When I ran last November, I did absolutely nothing with tire pressure,
just went and staged after arriving at track.
Some people say to increase the pressure of the front tires to decrease rolling resistance.
As I lowered mine, my trap speed got worse.
Is tuning that JDM ENGINEERING does done for a SCT tuner or Predator tuner? I would like to get my car properly tuned(loose the canned tune) and would like to be able to keep it in my Predator.
This is good info to know. I thought that since the stock rubber is only 235, that it wouldn't help all that much to let a bunch of air out. It's not gonna make the contact patch all that greater.
