Weight reduction on GT....anyone?
Old Jan 21, 2006 | 07:38 AM
Tilt's Avatar
Hi all,
Just curious if anyone has started in on weight reduction for the GT. I've seen some tubular front suspension pieces, radiator frame, etc. I'm sure there are lighter front body panels in the aftermarket. I've also seen some 'rear seat' removal kits (carpet to cover where the seats were located). Anyone do this yet? I'm not looking to do anything like this, just curious if anyone has taken the stang diet. How much extra weight do you think there is in this car?
Tilt
Old Jan 21, 2006 | 09:28 AM
dhof303's Avatar
I have done the k-member and radiator support but got all the weight plus some back with the nitrous/turbo/intercooler/increased oil capacity. I did start having my wife drive in competition which is good for about 35 or 40lbs of weight off with driver. Prior to the install of all of the go fast goodies we got the weight down to 3390 with driver. You could nock another 100lbs off with a set of Bogarts and a drive shaft.
Old Jan 21, 2006 | 09:08 PM
softbatch's Avatar
I talk to cones.
I take out the spare and jack
Old Jan 21, 2006 | 09:13 PM
spyder7724's Avatar
also have k-member/a-arms and coilovers. i may take out the seats and replace with a delete kit rear and use a butler built seat for me. that should lose another 125lbs. i think i can get it down to about 3200-3300 with my fat butt in it. trying to run 11.99 N/A with an auto. ?can it be done? i may have to add some weight and go with a 5.4 next winter to reach my goal.
Old Jan 22, 2006 | 12:40 AM
T-stang's Avatar
I managed to lose 110 lbs by buying my wife a bus pass! (And it only cost me $35!)
Old Jan 22, 2006 | 09:11 AM
hawgman's Avatar
Best mod so far!
Old Jan 22, 2006 | 10:10 AM
Rampant's Avatar
For those with the K-members, is there a noticeable difference on the street? 20-40 pound weight savings doesn't sound like it would be all that noticeable.
I am more about the driving feel than actual track times. If ti makes the car better balanced and more fun ripping through hard right turns, then I am all for it. But, I just am not sure if it helps.
On a different note, are there really any differences between the different k-members out there? If so, what do you run and why?
Old Jan 22, 2006 | 10:52 AM
spyder7724's Avatar
i haven't noticed any difference on the street regarding the k-member just the soft front springs feel different. i have an AJE k/member and a/arms. their stuff is very light and probably would not be sutable for corner carving. mine seems like a drag oriented piece. when combine with the rad support/sway bar delete you will lose about 80-100lbs. mine really doesn't handle bad considering there is no sway bar. i was surprised at that.
Old Jan 22, 2006 | 02:22 PM
dhof303's Avatar
Originally posted by Blazing Saddles@January 22, 2006, 11:40 AM
I have a pair of Kirkey Pro Street seats sitting in the garage. I need to fabricate the mounts for them.
Food for thought, though I know you like to fab things up it might be worth looking into. I know they are for an 04 and earlier but I think they might be making an 05.
http://www.rigidracecars.com/products.htm
I noticed immediately that there was a difference on the street with the k-member. At least in the rigidity category. After removing the sway bar the car had a lot of body roll and felt as if it creeked and groaned around corners and uneven pavement. After the k-member intall most of that feeling was gone, still a little body roll but the car is very predictable now.
Old Jan 22, 2006 | 06:15 PM
SRQ05GT's Avatar
Start with this http://forums.bradbarnett.net/index.php?showtopic=43260
Old Jan 22, 2006 | 06:51 PM
spyder7724's Avatar
Originally posted by Blazing Saddles@January 22, 2006, 2:32 PM
Ron. I'll be doing the K-member A-arms and struts soon. What brand struts did you use and what spring rate did you use. Thanks George.
since at the time no one made drag struts i bought a kit from ground control and used the stock struts. santhuff now makes a drag strut...go figure. my front spring is 175# 10" long and may need to be a little stiffer. i still have about 2.5-3" of travel left when sitting still. the rears are supposed to be 150# 10"springs but they sent me a spring that was too short so i cut the stock spring and will exchange the springs for a 10" 150#. i think 200 or 225# fronts may be a better choice for street&strip but for now i'll stay with what i have. i haven't run like this yet and still don't know what to do about rear suspension. i think i'm going to make a torque arm. they seem to work good on those bowtie cars and should not kill my ride quality.
CiniZter
25
Apr 28, 2016 05:41 PM
Sep 8, 2015 10:45 AM
earl610
Sep 6, 2015 05:48 PM
Kestral
Sep 5, 2015 11:50 PM
davelev213
Aug 27, 2015 01:54 PM
