Weighed my Deluxe Automatic
These car are so fat! I've shaved 5 lbs off so far by getting rid of the factory mufflers, the only other things I can think to do is add aluminum LCA's, and cut a coil out of the rear springs. Everything else I have done and plan to has/will add weight.
Originally posted by nasty3valve@May 30, 2005, 8:12 AM
some reacing seats, rear seat delet and k-member will save you a ton of weight!
Originally posted by BAKNBLU@May 30, 2005, 9:24 AM
The K member and A arms on the 05's are quite a bit lighter than previous years.
im sure these will still save us some good weight!
http://ajeracing.com/05stang.htm
