Water In The Trunk
Old Jan 9, 2007 | 09:13 PM
RadBOSS's Avatar
Water In The Trunk
To install my Tokio Spec D's this weekend I had to remove the trunk outer liner panels to gain access to the upper shock mounts. Quite by accident I noticed that there had recently been standing water collected near the pocket created by the fenderwell along the quarter panel. This was only happening on the driver side. Has anyone else out there had such a discovery? If so, was the cause determined and cured? My concern long term is the potential to create a rust site.
Old Jan 10, 2007 | 06:00 AM
there is a thread around here that goes in to detail about the gaps in the rear wheel wells as well as other areas that we should under coat.
Old Jan 10, 2007 | 06:13 AM
Here ya go
http://forums.bradbarnett.net/showth...ght=hole+wheel
Old Jan 10, 2007 | 09:11 AM
ski's Avatar
ski
I had the same problem with my 05 S197.
I also noticed that the water in that same area was slightly dirty, and had grit laying at the bottom. This told me that it was being splashed up there by the rear driver's side tire. So I sealed up all of the suspect seams in the wheel well area with duct seal, dried out the pooled water, cleaned out the grit, and sprayed water from a hose into the wheel well. The water was still getting in there. Since all of the seams in the wheel well were fully sealed, I then checked up by the gas tank filler pipe with a flashlight. Up there I found an unsealed seam around the gas filler pipe flange. Sealed it, dried out the pooled water, sprayed into the wheel well, and this time it remained dry. And it has remained dry since it was sealed over a year ago.
Old Jan 10, 2007 | 07:09 PM
RadBOSS's Avatar
Hey thanks. There is a film of dirt in mine as well. I eyeballed the gas filler, but not completely yet. I am hoping its not the rear glass or quarter window. I pan to look at next time I go thru the carwash as well.
Glenn - thanks for the thread reference. Will do a complete inspection. So what is POR-15?
Old Jan 10, 2007 | 07:21 PM
http://www.por15.com/
Old Jan 11, 2007 | 11:50 AM
RadBOSS's Avatar
Originally Posted by Glenn
Thanks ... looks like similar to a product Eastwood sells.
Old Jan 11, 2007 | 03:25 PM
I'm sure it is I would think autozone or pepboys would have some thing that would work well for us
Old Jan 12, 2007 | 03:16 PM
ski's Avatar
ski
You're welcome.
I doubt if the rear window is the cause. Mine was leaking, and it soaked the trunk matting, but none of the water got into the quarter panel area you're referring to. Some silicone caulking solved the problem.
Old Apr 16, 2007 | 08:42 AM
adnlyn's Avatar
mine is on the passenger rear. anyone else have it there ifso what was done to fix it.
Old Apr 16, 2007 | 10:18 AM
holeshot's Avatar
i undercoated my rear fenderwells with 4 sets of pirelli's. fairly expensive, but it keeps the water out.
Old Apr 16, 2007 | 10:21 AM
adnlyn's Avatar
thats a good one
Old Apr 16, 2007 | 10:51 AM
mvon919's Avatar
I noticed there's water somewhere inside my trunk lid or my CDC ducktail... when I open or close it, I can hear water splashing...
Old Apr 16, 2007 | 11:19 AM
holeshot's Avatar
I have that same problem. I think its coming from the GT badge in the rear. Somehow it is holding water and it runs out when you open the trunk.
Old Apr 16, 2007 | 11:21 AM
adnlyn's Avatar
how about the rear fender well or where the spare tire goes
Old Apr 16, 2007 | 08:46 PM
TillmanSpeed's Avatar
Former Vendor
POR15 is great for ex's cars.
Old Apr 17, 2007 | 10:07 AM
Arrow's Avatar
I found some sand, a rock, a bungie-cord and a handful of change once when cleaning the trunk out. I can only assume it all came from inside the trunk, though, 'cause I can't remember having run over any hippies lately...
On a more productive note, I have noticed that the seal can get pinched up around the trunk lid, and when accelerating the water in the trough leaks through like a waterfall...obviously. I noticed this one day while riding in the rain with the back seats folded down. Poking around under the disgustingly cheap trunk carpet...rug...thingies...there's a lot that can leak under the right conditions.
Old Apr 17, 2007 | 07:47 PM
RadBOSS's Avatar
I have not figured out the source yet. The carpet / liner is not getting wet, so its not coming from above. Did some basic inspection of the wheel house but nothing looks obvious. I need to pull the rear tire off so I can get a beter look around that area.
Old Apr 18, 2007 | 10:00 AM
mvon919's Avatar
Maybe... I suspect I'm carrying excess weight of water in my ducktail or SHR honeycomb panel...
Old Apr 18, 2007 | 10:55 AM
theedge67's Avatar
[quote=Arrow;894002]I found some sand, a rock, a bungie-cord and a handful of change once when cleaning the trunk out. I can only assume it all came from inside the trunk, though, 'cause I can't remember having run over any hippies lately...quote]
Mpaps
Oct 11, 2017 08:06 PM
Feb 10, 2017 07:12 PM
TMDM
Sep 24, 2015 07:00 PM
BigHoss
Sep 21, 2015 10:03 AM
Beouch
Sep 16, 2015 06:14 PM
