Valve Covers??
Old Feb 19, 2008 | 02:43 PM
StangPower05's Avatar
Valve Covers??
Hey guys, i got a question. I am looking into buying a used set of FRPP valve covers obviously for an 05+ and was wondering if i was able to re-use the gaskets and bolts that are on my stock valve covers?? Any advice would be greatly appriciated.
Old Feb 19, 2008 | 02:46 PM
GRAYPNY's Avatar
Yes. The gaskets on my 05 were fine when I swapped mine out a couple of weeks ago. Bolts aren't a one time use so that shouldn't be an issue either.
70MACH1OWNER's Avatar
Yes you can. There cars have reusable gaskets in many areas of the engine. Not like the old days of cork or paper gaskets that got hard and brittle in about 5,000 miles. Just be careful transfering them.
Scott
Old Feb 19, 2008 | 02:47 PM
You still pretty quick on the keyboard there old man!!
Old Feb 19, 2008 | 02:50 PM
Scott
So, im assuming that the bolts or studs are not a one time use either right??
Old Feb 19, 2008 | 03:00 PM
johnnyluvchx's Avatar
cam covers
you can reuse the gaskets and bolts. just tighten bolts to torque specks. go to taco bills how to list he has a great write up on doing this. I personally changed my covers twice already and not had a problem using the old rubber gaskets
Old Feb 19, 2008 | 03:20 PM
+1
Old Feb 19, 2008 | 03:22 PM
+1
+2!
Old Feb 19, 2008 | 03:53 PM
GRAYPNY's Avatar
On a side note. Did anyone have to change out their gaskets when they went to the delete plates? These gaskets seem to hold very well and are very pliable but I was wondering?
Old Feb 19, 2008 | 04:10 PM
jayguy's Avatar
No, you don't have to change out the intake manifold gaskets either. I just did both the delete plates (actually put the stock plates back in) and the valve covers at the same time a few weeks ago. All gaskets are re-usable there.
Old Feb 19, 2008 | 04:25 PM
I really appriciate all the help! Thanks Alot to everybody!!
Old Feb 19, 2008 | 04:39 PM
Mine were very pliable and worked just fine. No issues when reusing them.
Old Feb 20, 2008 | 01:36 PM
blkstang06's Avatar
..+1
lsingggh310
Ecoboost
Feb 7, 2016 12:26 PM
Airborne42
Sep 24, 2015 10:27 AM
bconboy
Sep 10, 2015 02:31 PM
BavarianStang
Sep 5, 2015 05:55 AM
