Valve cover removal/reinstall
Old Oct 10, 2007 | 02:23 PM
rrobello's Avatar
TMS West Coast Correspondent
simple and stupid question...last night I removed the valve covers to paint them but the passenger side was a ***** to get out because of all of the wiring and crap, is there a quick easy way to remove all of the harnesses so I can reinstall it without scratching the **** out of it that wont require a bunch of extra effort or do pretty much have to remove a bunch of crap? I had to loosen the battery mount and move it just to pull the cover out.
Old Oct 10, 2007 | 02:55 PM
DavidM's Avatar
Remove the coil packs, remove the nut on the front top of the motor that holds down what looks like some sort of electronic pickup/fuse link. After you paint use an old T-shirt over the freshly painted covers while slipping under the wiring. It's a PITA but should be ok if you take your time. I did mine and had no scratches after install. Just took my time.
Old Oct 10, 2007 | 02:59 PM
05fordgt's Avatar
Robello, I removed my valve covers with my father's help (he held the wire loom out of the way while I got the blue ones on. And I didn't even take off my battery, and kept the strut tower brace installed too. Only thing I removed, was the coils, like DavidM mentioned. Its easier with an extra set of hands.
Old Oct 10, 2007 | 03:00 PM
rrobello's Avatar
thanks Ill look for that, and good tip on the tshirt I wouldve completely overlooked something that simple
Old Oct 10, 2007 | 03:18 PM
ren274u's Avatar
check out taco bills hotlinks for his write up.
i just painted mine this weekend, and followed his steps minus removing the coil packs.
Old Apr 2, 2008 | 08:28 PM
GottaHaveIt's Avatar
Hey how's about about a boat we seen this today ?
http://i112.photobucket.com/albums/n...r/DSC00916.jpg
http://i112.photobucket.com/albums/n...r/DSC00915.jpg
http://i112.photobucket.com/albums/n...r/DSC00914.jpg
http://i112.photobucket.com/albums/n...r/DSC00913.jpg
Old Apr 3, 2008 | 07:14 AM
RKNMACH's Avatar
After all these years of calling them "valve covers" I guess they are now referred to as "cam covers" - times do change.....
Old Apr 3, 2008 | 07:39 AM
MaverickMLFD371's Avatar
try putting them on with a whipple blower in the way, that was a bigger PITA!!!
as for the passenger side, it was easy to get to all the bolts, and I had my dad assist me with the wiring harness. I just disconnected the wires from the coilpacks and he grabbed the whole harness and pulled it away from the covers giving it a nice wide open gap & pulled out the covers. did the same thing installing the new covers, and I coverd the valve covers using the styrafoam paper sheet that came with the covers to prevent it from scratching it when I installed them.
Old May 17, 2008 | 05:04 PM
blkstang06's Avatar
bump
Old May 17, 2008 | 09:56 PM
odiaz's Avatar
I wrote this set of instructions 2 years ago. I had trouble getting at the rear bolts on the cam cover without removing the battery. After I pulled the battery and battery tray, getting at the bolts was fairly simple.
here's a link to my instructions:
http://www.cherod.com/mustang/HowTo/ValveCover.htm
Old May 18, 2008 | 09:14 AM
06stage3's Avatar
Originally Posted by MaverickMLFD371
try putting them on with a whipple blower in the way, that was a bigger PITA!!! as for the passenger side, it was easy to get to all the bolts
Exact opposite with a Roushcharger. Passenger side was the PITA and the driver side was a piece of cake. Throttle body sits over the valve cover on the passenger side.
Old May 18, 2008 | 10:17 AM
travelers's Avatar
Very good artical
Old May 18, 2008 | 11:49 AM
LEO_06GT's Avatar
There's always the Taco's how-to's.
http://forums.bradbarnett.net/showthread.php?t=453730
lsingggh310
Ecoboost
Feb 7, 2016 12:26 PM
Airborne42
Sep 24, 2015 10:27 AM
bconboy
Sep 10, 2015 02:31 PM
BavarianStang
Sep 5, 2015 05:55 AM
