URGENT....how to add refigerant long tube install gone wrong
Old Feb 23, 2008 | 02:15 PM
oneunderone's Avatar
my little bro was helping install my long tube and needeed to get to a bolt so he unplugged the wire that goes into the compressor or
something directly beneath the stock header bolt and out shot tjis green liquid. when i saw what the part he pulled was connected to it says r134 refrigerant required what is this stuff and how do ui add it back?
Old Feb 23, 2008 | 03:02 PM
KuruptedStang's Avatar
R-134a is the refrigerant used by the car to run the A/C. It used to be R-12, but it had adverse effects to the environment so you have to be licensed to get the R-12. R-134a is easily obtainable at your local auto parts store or even Wal-Mart. All you need to add it back is the adapter hose that goes to the shrader valve on the car from the can.
Old Feb 23, 2008 | 04:31 PM
06GT4RAD's Avatar
Go to a qualified A/C Tech and let them do it. It can be very dangerous if you do it wrong or over fill or under fill the system.
I cannot imagine what he removed that would have caused the Freon to escape like that. Unless he unbolted the line right off the back of the A/C compressor. He is lucky he did not get burned from the freon
Old Feb 23, 2008 | 07:08 PM
rick06gtmustang's Avatar
A/C
They sell a kit thatcomes with a gauge,so you do not over chardge the system....I'm a EPA certified HVACR tech and the only thing you may want to do is evac the system if it does not work properly...Moisture is not kind in a system.
Old Feb 23, 2008 | 07:11 PM
2kanchoo's Avatar
If they made this kind of mistake to begin with it would probably be safer for everyone involved if they went to a mechanic.
Old Feb 23, 2008 | 08:51 PM
tom281's Avatar
+1.......... right on.
Old Feb 23, 2008 | 10:13 PM
ok
Very good point
Old Feb 23, 2008 | 10:24 PM
goldenpony's Avatar
A/C
Yes, get thee to a pro.
Jtm90fox
May 22, 2016 01:55 PM
GT/CS Guy
Aug 13, 2015 07:54 PM
ClayP
Aug 3, 2015 09:00 PM
