Upper Strut Mount (SM001) installation..
Old Mar 28, 2007 | 08:39 PM
YaoNYC's Avatar
hi all,
i realized i did not replace this when i installed tokico d-specs.
i heard this is what is causing the clunking.
is this easy to install after the fact? does i have to remove all my struts?
thanks!
Old Mar 29, 2007 | 06:32 AM
Stig's Avatar
You'll have to remove the front struts & springs to replace the strut mount.
- If you're getting the clunking that is.
The clunking can be caused by the strut mount rubber seperating - so check this is the case, or you may have a different problem.
Old Mar 29, 2007 | 07:16 AM
tr6nut's Avatar
Upper Strut Mount
I just purchased a new set and I have'nt installed them yet. Just looking at them and playing with them, it appears that there is little or no lubricant/grease on the bearings (very rought movement). Do they need to be greased before installation?
Old Mar 29, 2007 | 02:56 PM
RobK's Avatar
Generally they're non-serviceable. Of course there's no real reason why not to.
Old Mar 30, 2007 | 05:48 PM
YaoNYC's Avatar
i just saw on steeda's website they have an enhanced version.
is this worth it?
heavy dute upper strut mounts. very pricey though at $299.
http://www.steeda.com/products/heavy...nts_street.php
is this necessary??
thanks...
Old Apr 2, 2007 | 06:30 AM
Stig's Avatar
is this worth it?
is this necessary??
thanks...
Necessary - no. But they will stop the clunking.
samjluck
Oct 26, 2015 05:17 PM
RoushRS3
Sep 29, 2015 08:03 PM
AJ_Trevino15
Sep 28, 2015 07:51 AM
robjh22
Sep 8, 2015 12:31 PM
