Upgradability of the Saleen supercharger?
For positive displacement superchargers I'm leaning toward the Saleen. I'm not really a Saleen fan per se, but I just like the compact design and not having to install a big intercooler. Oh, and I think it has the best sound The downside is, at some point I'll want more boost out of it. When that happens, I'm a little concerned about the integrated intercooler..thinking it's maybe too small?
So my thinking was that when that time comes, I could perhaps spray methanol. But I've heard that horsepower gains from spraying the Snow kit into an intercooler aren't very big, because of some kind of vaporization issue. Do you think this would also be true with the Saleen's integrated water-to-air intercooler?
I guess adding Nitrous would be another option.
I was acually just looking at a saleen blower today. From what ive gathered, it seems the saleen is most efficient at low boost levels. At 5lbs your geeting about 400hp (I dont if its rwhp or fwhp) but at 10lbs your lucky to get 420 rwhp. A whipple at 10lbs of boost is good for about 475 rwhp. I know saleen advertises a 475hp kit, but i think they mean 475 flywheel hp. And From what ive seen the saleen has two intercoolers http://www.lightningforceperformance...-gt-p-316.html look at "in depth details".
The Saleen also has a water to air intercooler in use in front of the radiator besides just the integrated intercooler under the twin screws. My intercooler water temps are normally about 20 degrees over the ambient temperature. The 475 HP upgrade kit is approx 420 RWHP at 8 psi
OR, you could get the FRPP (whipple-type) SC, and get it installed at the Ford dealership, and your car still be covered by warranty....just got that exact setup quoted by the service manager at McRee Ford in D i c k inson, TX, for under $7k (labor included). They needed 10 days to get all the stuff, and a full day for the install...which means drop it off Monday and pick it up Thursday if you're lucky, porbably Friday LOL. 500 Flywheel hp (425 rwhp) with a warranty....what's not to love!
That intercooled or non? And they still give a warrenty on drivetrain? ... Wow
I wonder if they'll honor something like that at my dealer.
If, like will be my case, you buy the car then 8 months later you decide to do the supercharger, the powertrain warranty remains intact but the supercharger gets only a 12 month warranty.
Pretty sweet, given that the FRPP/Whipple seems to have less issues than the Kenne Bell and Saleen. BTW, my dealer is also a Roush dealer, and would also install the Roush SC and keep the powertrain warranty intact. (NOTE that the Roush is a Roots type, which uses more horsepower to turn and produces less boost with higher temperatures than the twin screw type like the Whipple/FRTPP)
I don't see how this would be any different for other Ford dealers, other than the a s s hole factor, of course. I suggest you go introduce yourself to your service manager, and be totally candid with him, and ask him about installing a Ford SC, and wanting to give him the business so that you can keep your warranty intact. That's what I did. In fact its a good idea to do even if you weren't going to install a SC, just for when you have a warranty matter that may be iffy, it can't hurt to be someone he recognizes and is even friendly with.
Note something that I failed to mention: the dealer said the warranty would be intact if a Ford dealer installed the SC, so you couldn't buy it and have your local speed shop do it or do it yourself, as that would void the warranty.
I did my research on this and read the fine print...if you were to buy a new Mustang, and before taking delivery, e.i. as part of the purchase, you have them install the supercharger, then the powertrain warranty remains in effect and the SC has the same warranty for the same length of time.
I ask because I just went all engineer bench racer and spreadsheeted a bunch of positive displacement supercharger kits. I think I've changed my own mind. For the buck, you really can't beat the Whipple numbers. It's the only good kit I see that includes a real fuel pump for the same price as the rest. It also seems to do much better at keeping up with the torque than either the Saleen or the Kenne Bell. The only thing I don't like about it is the PCM setup, but there's always the "tuner kit" from Whipple and a nice fuel setup.
The Saleen has many upgrades available. JDM racing has everything from mild to wild and lots of guys have been running their setup for years without any problem. If it is a street car (i.e. less than 500 hp) Saleen is a good choice. If you are going to upgrade I strongly suggest you check out JDM.
If you want really big hp (race). Look to Kenne Bell or Whipple. They both make street versions of which I personally think the Whipple (FRPP) kit is the best put together package. Each has an advantage. There are lots of threads, just search around.
You can't go wrong with any one of the three. But Saleen will not compete with the big boys, if that is what you want.
It says on the FRPP website right in the product description for any supercharger that it will void your warrantee. If you did find information to the contrary, I'd like to see it, because that would indeed be sweet. But even if that were true, the fact that FRPP put a disclaimer on the website product description might provide legal grounds. I dunno, sounds very grey area to me.
I like the idea of a "safe" 425 rwhp (translates to 500 flywheel hp at a 15% driveline loss). I thought the general consensus was that the 3v 4.6 was good for 500 flywhel hp on stock internals, and that anything beyond that you should really get a built engine.
Again I reiterate my question from above: the FRPP SC can't be tuned for more HP on a dyno? Or maybe its the $$ that you object to....I'm open for suggestions....
Im looking into getting a whipple hopefully by the end of summer, and from what ive seen the intercooled version is good for about 475 rwhp which is plenty for me.
I'm pretty sure he is saying that it is an expensive proposition. The Whipple can definitely go up the HP ladder with a built bottom end. The warranty would be out the window at that point and you'd be better off buying from a reputable tuner, both price and HP wise.
