"The Ultimate Mustang Driveshaft" with Free UPS-100% Satisfaction Guaranteed
Well 65 minutes of labor and the stock shaft is outta there.......
But I'm done for tonight..... I don't have a friggin' 8mm Hex-bit driver thingamabob and I need to pickup a 12mm 12 point socket. I got the 12mm bolts off using my rachet wrench but I need the socket to torque them back down.... I used a 1/4" rachet to drive in the 8mm bolts but certainly can't put much pressure on them or else I'll take the chance of stripping them. Need the driver so I can torque them.....
So tomorrow I'll pickup these 2 things and hope to get'er done.
Tom, should have read this first..
Be advised, a 12pt socket may not fit squarely on those bolts (u-joint to trans output flange), see note in step 11.
Good luck with the rest of the install.![Thumb](https://themustangsource.com/forums/images/smilies/thumb.gif)
![Stickpoke](https://themustangsource.com/forums/images/smilies/stickpoke.gif)
![Biggrinjester](https://themustangsource.com/forums/images/smilies/biggrinjester.gif)
Shaft is installed.........
IT IS AWESOME! Very light, great materials, and a noticeable increase in performance with no problems. There is a tad more noise while driving but nothing really noticeable unless you listen for it.... but that's to be expected when you decide to lose that heavy, rusty stock shaft. No vibrations and no problems atleast up to 100mph (that's as high as I've taken it).
Robert and David both were great to deal with, answered all of my questions, took calls before normal business hours, and Robert even offered his cell # to help me thru some install issues that I had.
Great product, great support, great price. Super fast shipping- shipped same day I ordered, arrived to me the next day! HIGHLY RECOMMENDED!
Location: New Carlisle, Ohio (20 miles north of Dayton)
Good Deal Tom.. I had a thought about the extra noise you say your hear. I bet it is the Prothane mounts transfering more NVH and not really anything caused by the drivshaft. Just a thought.
Scott
![Exclamation](https://themustangsource.com/forums/images/icons/icon4.gif)
just a word of caution that will probably get stepped on by the seller of these shafts...if you are lowered 1.5" -1.75" the squat that the car takes on a hard launch or hard 1-2 shift will rub a 4" shaft on the tunneling plate in the car...and may rub the tunnel at the rear about a foot fwd of the pinion. I had to beat and bend the plate and have not done anything to the other spot further back yet...This is what mine is doing with a Coast unit...I have FRPP springs and have tried it with stock and drag shocks set at 50/50....I have non adj j+m lcas and a spohn adj upper...I have cured the rub/hit slightly by adjusting the UCA -2 degrees...could go more but want to lessen the chance for vibes...If i had the choice again i would do a 3.5" shaft...
Robert
Robert
How sturdy is the adapter? Im running about 350hp @ the wheels and I do race the car> Its a street car that I race occasionally. I`m just concerned about swapping my yoke out and getting the nut torqued correctly if I don`t use the adapter.
Robert
#40
Robert
