U/D Pullies
Old Apr 18, 2005 | 08:01 PM
fastrek82's Avatar
Will it harm my charging on the battery, Or will there be any other problems???
Old Apr 18, 2005 | 08:20 PM
O5GT's Avatar
properly installed, you will encounter no problems
Old Apr 18, 2005 | 10:06 PM
169stang's Avatar
I have over 12,000 miles and I haven't had a single issue yet.
Old Apr 19, 2005 | 05:17 AM
2005RedGT's Avatar
yes. however, if you have a huge stero, I would not do it - but under normal use they work very well. And yes, they hold up to the Shaker 1000 system.
-Bryan
Old Apr 19, 2005 | 06:48 AM
70MACH1OWNER's Avatar
HI Guys,
I have been following the UD pullies issues and one thing I have not seen yet is does the air conditioning still seem up to the task?? I guess my question is directed to you guys down south and out in the southwest. I live in Ohio so if you guys with UD pullies in the hotter climates have no issues with your air conditioning I would guess I would have no problem at all.
Thanks Scott
Old Apr 19, 2005 | 06:50 AM
2005RedGT's Avatar
No problems so far, but lets let the AZ guys/gals chime in
-Bryan
Old Apr 19, 2005 | 07:52 AM
tx2005gt's Avatar
[quote=70MACH1OWNER,April 19, 2005, 6:51 AM]
HI Guys,
Thanks Scott
/quote]
i have not done ud pullies for this reason. living in texas and having a black gt i need the ac to work as hard as it can.
Old Apr 19, 2005 | 07:54 AM
169stang's Avatar
My A/C runs every day. It will be different once July rolls around though. It'll be mid 90's everyday.
Old Apr 19, 2005 | 08:33 AM
hawgman's Avatar
I am in North Texas and am holding off for that exact reason. Nothin' like a Texas summer to make you regret doing something that is going to interfere with your A/C operation! Besides the fact that the A/C in the stang isn't really anything to brag about in the first place. Now in November or so, if everyone is still happy, I might consider it.
Old Apr 19, 2005 | 11:37 AM
HOTLAP's Avatar
I have had them installed for 1.5K miles now and living in SoCal my A/C works fine.....I'm confused as I thought the smaller diameter of the crank pully was offset by a larger diameter water pump pully - so the belt was actually spinning at the same rpm's as b4.....isn't that why we can still use the stock "S" belt?
And other things being equal - wouldn't a smaller diameter crank pully spin faster -and thus spin your A/C and alternator even faster? I had assumed (perhaps incorrectly) that the increase in water pump pully diameter offset the smaller crank diameter and the alternator pulley is no longer changed to keep it spinning the same rpm's so you don't have any voltage loss with ud pullies?
Old Apr 19, 2005 | 03:43 PM
LordBritish's Avatar
I live in L.A. so I NEED A/C in the summer !!!
I'm going to wait to hear what some other folks say.
Old Apr 19, 2005 | 05:26 PM
SixtySix's Avatar
I won't do em. To me there's not enough of gain in using them. Living in the roasting desert I just can't bring myslef to mess with anything that "could" have an effect on my precious accessories.
I'm sure lot's of people here in the desert use em and love em, I'm just not one of them.
Old Apr 19, 2005 | 05:36 PM
38special's Avatar
It was 82 in DC today. Ran with the windows open and the compressor off. Not too bad. If it gets hotter, I may tint my windows a bit. (This is how you run it with ud pullies and it messes up your ac )
Tech guys at the local shops are quoting only a 2 hp gain, regardless of what the manufacturer's are stating. Not worth it for the risk. :nono:
Old Apr 20, 2005 | 03:13 PM
Thanks 38Special,
I appreciate your honest opinion. I will be using this car as a daily driver averaging speeds of 35 MPH. The small HP gains from the UD pullies is not worth it to me to lose the AC cooling effect. You helped me make up my mind. NO UD PULLIES. Thanks Guys
Scott
Scothew
Apr 20, 2023 02:33 PM
Jtm90fox
May 22, 2016 01:55 PM
scotts05custom
V6 Performance Mods
Dec 7, 2005 10:21 PM
jayguy
Jun 16, 2005 11:29 AM
Scothew
1994-2004 V-8
23
Mar 13, 2005 06:31 PM
