turning traction control off?
Old Jun 13, 2006 | 03:46 AM
vc4life's Avatar
is there a way to set the default to off instead of on so i dont have to turn if off everytime i get in the car?
Old Jun 13, 2006 | 05:19 AM
outdoorstom's Avatar
You can turn it off using a SCT Xcal. Once you turn it off though, the dash button is useless. You have to turn it back on using the tuner.
Old Jun 13, 2006 | 06:30 AM
Shea's Avatar
There is also a way to set the default to off. There is a black box you can buy which plugs into the wiring harness and does what you want. I dunno who makes it though.
FWIW, I turned mine off with my Xcal for a while, but when you do that, not only is the dash button useless as stated above, it makes the "skidding car" light on the dashboard stay lit up all the time. It annoyed me so I just set it back to normal operation.
Old Jun 14, 2006 | 06:38 PM
AWmustang's Avatar
In Car and Driver's test of the Shelby they said there was an integrated launch control in the traction control.
they just held the RPM's to 3500, dumped the clutch and floored it. The system got them to 60 in 4.6 sec.
when they turned the system off they were slightly better at 4.5 sec.
If the GT has the same system why would you want it off.
Old Jun 14, 2006 | 09:25 PM
Slofoot's Avatar
The other downside to turning it off with the tuner is the sliding car light on the dash stays on at all times or if you have the IUP it says "check traction control" at all times. Mine is off on my race tune (one less thing to remember in the staging lanes) and on my street tune I have just gotten into the habit of turning it off. My wife drives the car daily and I want it on for her. Bad for the S/C'd engine or not.
Old Jun 18, 2006 | 03:20 PM
Bullitt995's Avatar
1. Car and driver has some of the worst drivers ever. I think they pulled a 12.9 or something retarded with the new GT500. Dumping the clutching and flooring it is pretty much the worst way to launch the car.
2. Go try it for yourself at the track, traction control on for one run, traction control off for one run and see for yourself. That is if you know how to drive properly.
Old Jun 20, 2006 | 01:35 PM
AWmustang's Avatar
I would love to, but they don't allow verts on the tracks around here unless you have a structural roll bar.
lakersfreak
Jun 13, 2022 12:29 AM
trackpack13gt
Jul 25, 2017 05:29 PM
ricky1728
Feb 11, 2016 07:25 PM
yabutt
Oct 23, 2015 01:05 PM
