Transmission after drag racing
Old Jul 23, 2006 | 06:02 PM
2006GT500's Avatar
Any having any issues with their transmissions after drag racing? I raced last night and my 2nd gear is grinding like crap. It started after a few passes so I figured the tranny was just hot so I let it cool down and it did it once again. But today it's doing it everytime I shift from 1st to 2nd. I can downshift from 3rd to 2nd no problem but 1st to 2nd sucks. Any clue what's wrong. I plan on taking it to the dealership tomorrow but wanted to get any info I could get here first.
Old Jul 24, 2006 | 08:55 PM
area5179's Avatar
I do have some tech knowledge but am by no means an expert, but here it goes. First, did you shift using the clutch (grannyshift) or did you powershift (shift without using the clutch). I suspect that you were powershifting given your problem, so it sound like you damaged or ground up a syncro gear or second gear entirely. If this is the case, there are expensive repair's in you future. If you shifted using the clutch, then I can't say for sure what the problem might be. But take it to the dealer no matter what so they can check it out!! Hope this help's
Old Jul 25, 2006 | 12:44 AM
Bullitt995's Avatar
He probably was powershifting (you do use the clutch when powershifting) or he has missed 2nd a few times. Either way it's the syncro.
Old Jul 25, 2006 | 08:39 AM
2006GT500's Avatar
I powershifted on 3 out of the 5 runs and it was only after powershifting those runs that it started having problems. I also think it is the syncro. I don't know why that couldn't be fixed under warranty but if you guys know something I don't let me know.
Old Jul 25, 2006 | 12:30 PM
Bullitt995's Avatar
The worst thing they can do is say no. That's a big labor fix so if I were you I would get my car as close to stock as possible. Stock exhaust, stock pulleys, stock intake, AND DEFINATLY STOCK SHIFTER.
Old Jul 25, 2006 | 12:34 PM
2006GT500's Avatar
Talked to the guy and he said that he didn't see why unless they could determine without a doubt that my mods caused the problem that it wouldn't be a problem to fix. He also said that he would probably rather just put a new tranny in it than fix the one now.
Old Jul 25, 2006 | 05:13 PM
2006GT500's Avatar
New transmission should be here first of next week. No cost to me.
Old Jul 25, 2006 | 05:40 PM
jp's performance's Avatar
good deal glad they are doing the right thing.
Old Jul 25, 2006 | 07:39 PM
Vegasjay's Avatar
Good to hear your not getting screwed around...
Old Jul 25, 2006 | 08:44 PM
Eleanor Dreaming's Avatar
I think I would say a prayer of thanks to the Mustang Gods.
Old Jul 26, 2006 | 09:57 AM
2006GT500's Avatar
Oh I've definitely done that.
Old Jul 26, 2006 | 02:07 PM
Bullitt995's Avatar
Sounds like a cool dealer.
Old Jul 26, 2006 | 04:35 PM
RPM's Avatar
RPM
WOW, you dodged a bullet this time. Nice dealer!
Old Jul 26, 2006 | 05:03 PM
ford4v429's Avatar
legacy Tms Member
just be sure for 'description of problem' the words powershifting or dragstrip are not logged
I was at the strip last night too(second time- first time was 1984) got a best of 14.02 @ 102.25...10 runs all powershifted, I did bump second on the second run, but so far so good...wasnt like a 'grind me a pound' noise, just felt the teeth thru the shifter- like a almost instant buzz of 4-5 clicks as I pulled it back- very close to missing engagement/heavy damage at redline...luckily it just caught and went in, but just by dumb luck.
suprisingly hit third every time, got a chirp everytime...I woulda guessed to NEVER miss second, but I think getting caught up in the moment the clutch was coming up as the shifter came back...still cant figure out how i got third every time...now If I could just learn to launch...its all about that first few feet, and if you spin at all...a lot harder than I thought it would be with a stick(last time was my 302 auto 69- only ran a 15.6!).
ran a 14.4 with wife and kids in the car- they loved it
Old Jul 27, 2006 | 08:32 PM
AFChief's Avatar
Hate to go off topic, but could you explain Power shifting to the new guy?
Old Jul 27, 2006 | 08:55 PM
Bullitt995's Avatar
Keep your foot floored on the gas and shift as fast as you can.
Old Jul 27, 2006 | 09:11 PM
don_w's Avatar
And don't miss the gear...
tacbear
Sep 27, 2015 12:57 PM
southern stang
Sep 26, 2015 04:19 PM
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
Sep 16, 2015 06:44 PM
