Torque Converters
Old Jan 7, 2006 | 01:29 PM
Machine's Avatar
..did a search for this subject, but none that I could find that related directly to this...
Are their any available yet? If so, has anyone changed out their torque converters to a high-stall alternative?
Old Jan 7, 2006 | 02:50 PM
70MACH1OWNER's Avatar
Originally posted by Blazing Saddles@January 7, 2006, 3:21 PM
I have a TCI 3000 stall Street Fighter converter. It dropped my ET 4 1/2 tenths.
George,
Is your car driveable on the street with not problem or do you only use it at the track?
Old Jan 7, 2006 | 03:57 PM
SixtySix's Avatar
.4 ! That's great George! Somehow, I completely missed that mod. :scratch: How much was it, if you don't mind me asking?
Old Jan 7, 2006 | 04:06 PM
dustindu4's Avatar
9 is not my lucky number.
Originally posted by Blazing Saddles@January 7, 2006, 5:14 PM
It's very streetable. No problems at all. I drive the car everywhere, got 22,000 miles on it.
Man you have more miles than me, I'm at 20,170.
George is lucky enough to have a son with a full garage who "gets some lessons from the old man" how to do things if I remember. I wish I knew how to do stuff like that.
Old Jan 7, 2006 | 04:43 PM
dustindu4's Avatar
Found it here for $490
http://www.victoryracingengines.com/...hp?SECTION=103
$500 at summit
http://store.summitracing.com/default.asp?...t=egnsearch.asp
$492 at jegs
http://www.jegs.com/webapp/wcs/stores/serv...ategoryId=29449
Old Jan 7, 2006 | 09:41 PM
jp's performance's Avatar
13,300 and still not broken in yet don't worry dustin start to do little by little you will pick up on it very quick and save a lot of money.
Old Jan 7, 2006 | 10:44 PM
atomic_il's Avatar
How do you install these?? I don't get it.
Someone on anther site has a tci converter custom made at 3800rpms. It's pretty sweet
Old Jan 7, 2006 | 10:46 PM
atomic_il's Avatar
Old Jan 7, 2006 | 11:50 PM
Cleveland's Avatar
I believe it would be a smart idea to not just go out and buy a new torque converter or have yours modified until you know exactly what engine setup and power you will be running. With cams, head work and such on the way it would be best to hold off a bit. The cam almost dictates what TC you should use, well... the duration does.
Match your parts correctly folks or you may end up with a dog in your hands.
-Dan
Old Jan 7, 2006 | 11:55 PM
don_w's Avatar
I'm with you on this one Dan. I've been holding off on a TC change until after I get my supercharger installed.
Old Jan 8, 2006 | 09:40 AM
JST4FN's Avatar
I run a modified stock unit by Precision Industries offered thru Alternative Auto. It has excellent street manners and better performance, however I have not gotten any track times. Unless he changed convertors it would be the same one in Lidios car. I also use a supercharger too and it matches pretty well for the street anyway. To get maximum performance a higher stall would be needed that would ruin street driving.
Thanks Mike
Old Jan 8, 2006 | 10:30 AM
ren274u's Avatar
The whole high stall thing= bad street driving, just t/c overall confuse me. Anyone want to explain.
Old Jan 8, 2006 | 10:57 AM
Machine's Avatar
I dont intend on running a supercharger or any other form of power adder until a few years from now. My immediate goal is to get into the low-to-mid 12's with bolt-ons. So far, I've gotten 13.4et with a JLT2 CAI, Jet TB, Pypes X, Motive 3.90's and SCTXcal2 tune by Brenspeed.
I have yet to mount my BMR LCA's, still need to get my pullies as well as some drag tires. I was thinking these, plus some weight reduction and maybe a T/C would get me there...just wanted to see if it was an option...
Old Jan 8, 2006 | 11:21 AM
Machine's Avatar
btw, thanks for the info on the T/C's...
Old Jan 10, 2006 | 06:50 AM
Machine's Avatar
excellent article...thanks for the link!
Old Jan 10, 2006 | 10:43 AM
dustindu4's Avatar
it's inside your transmission, you have to remove your tranny to get at it. Luckily it's the first thing to remove inside your tranny so it's not like ripping the whole thing apart. It's kind of like a clutch on a manual tranny.
If anybody is really serious about doing this yourself, I have the Ford worksheets on how to do this. PM me and I will email them to you. I can't post it here because the pdfs are 3 megs each.
Old Jan 10, 2006 | 11:19 AM
Machine's Avatar
I'm interested...can you email them to ramirezrocky@hotmail.com please? thanks...
btw, I have remove a T/C from a tranny before (C4), but it doesnt hurt to see the specs and stuff on it...
