Top speed with governor removed via tuner?
I've personally never been on a good enough road to push mine much into the triple digit range. But since this post was originally about tire ratings it should be said. Speed ratings are for sustained speeds. So a 168+ mph tire could actually run at that speed continually with brief spurts well above that.
Well done!!! LOL!! Took that baby to 168MPH!! Nice job! Please be carefull.. Seriously, you have made your point, and it is much appreciated.. But on the serious side, be carefull man..
Also, is your car completely stock?
According to my metric converter 240km/hr = 149.13 mph. Real fast but not 168.
I took mine above where the speedo registered and then the governor cut it out. I think it was going a few mph over what the speedo said, probably 148.
And my girlfriend never woke up, LOL.
[quote=MSP,October 24, 2005, 6:15 AM]
2005 GT Mustang @ 175MPH in 4th gear= 7731 RPM
2006 GT Mustang @ 180MPH in 4th gear= 7952 RPM
2005 GT Mustang @ 175MPH in 5th gear= 5257 RPM
2006 GT Mustang @ 180MPH in 5th gear= 5407 RPM
So basically, its a pipe dream to run a 2005 or 6 Mustang GT @ 175MPH or 180MPH..
What the heck are you talking about here???? :scratch:
There is no difference in power between an 05 and 06.
Not to mention all the Ford GT quotes.
I'd check your source.... :notnice:
Originally posted by Infinity@October 23, 2005, 8:13 AM
The top speed isn't electronically governed. The car runs out of ***** before it runs out of gear.
You're kidding, right?
All of you thinking that taller gears means higher top end. You must be thinking about running in a vacuum. 155 is about the max un-governed stock top end because of drag. Look at the difference in torque/hp at given rpms. Unless a couple of you want to disprove the below theory by testing out your stangs (1 w/ 3:27's and 1 w/ 4:10's). I'll stick w/ the math.
3.55's in 4th
RPM/3.55*87.9645943005142(tire circumference)*60(min/hr)/5280(ft/mi)/12(in/ft)
3.55's in 5th
RPM/3.55/0.675(5th gear ratio)*87.9645943005142(tire circumference)*60(min/hr)/5280(ft/mi)/12(in/ft)
4.10's in 4th
RPM/4.10*87.9645943005142(tire circumference)*60(min/hr)/5280(ft/mi)/12(in/ft)
4.10's in 5th
RPM/4.10/0.675(5th gear ratio)*87.9645943005142(tire circumference)*60(min/hr)/5280(ft/mi)/12(in/ft)
RPM WHP 3.55 in 4th 3:55 in 5th 4.10 in 4th 4.10 in 5th gain @ mph
4000 215 93.85893545 139.0502747 81.26810264 120.3971891
4050 218 95.03217214 140.7884032 82.28395393 121.902154 +27whp @ 140mph
4100 222 96.20540883 142.5265316 83.29980521 123.4071188
4150 226 97.37864553 144.26466 84.31565649 124.9120837 +27whp @ 145mph
4200 227 98.55188222 146.0027885 85.33150777 126.4170486
4250 229 99.72511891 147.7409169 86.34735906 127.9220134
4300 230 100.8983556 149.4790453 87.36321034 129.4269783 +29whp at 150mph
4350 232 102.0715923 151.2171738 88.37906162 130.9319431
4400 233 103.244829 152.9553022 89.39491291 132.436908
4450 234 104.4180657 154.6934306 90.41076419 133.9418729 +27whp @ 155mph
4500 235 105.5913024 156.4315591 91.42661547 135.4468377
4550 238 106.7645391 158.1696875 92.44246676 136.9518026
4600 241 107.9377758 159.9078159 93.45831804 138.4567675 +21whp @ 160mph
4650 244 109.1110125 161.6459444 94.47416932 139.9617323
4700 247 110.2842491 163.3840728 95.49002061 141.4666972
4750 250 111.4574858 165.1222012 96.50587189 142.9716621 +13whp @ 165mph
4800 253 112.6307225 166.8603297 97.52172317 144.4766269
4850 255 113.8039592 168.5984581 98.53757445 145.9815918
4900 257 114.9771959 170.3365866 99.55342574 147.4865566 +7whp @ 170mph
3.55's in 4th
3.55's in 5th
4.10's in 4th
4.10's in 5th
3.55's in 4th
3.55's in 5th
4.10's in 4th
4.10's in 5th
3.55's in 4th
3.55's in 5th
4.10's in 4th
4.10's in 5th
Where can I get an Instrument Cluster that has KPH's as the main speed?
Right now I have MPH with KPH in small letters.
TOm
Originally posted by GhostGT@October 30, 2005, 8:59 PM
Your saying our stock cars are limited to 155 because of drag and NOT the governor? :nono: :nono: You have yet to test its abilities...
9/8/15 10:45 AM
