Tire size advice for 18x8.5" rims
Old Jan 15, 2007 | 06:53 AM
Louie's Avatar
I just ordered a set of 18x8.5" black Bullits (05+ offset) and I'm looking for tires. I found a great deal at a local store, but my question is: are 255/45ZR18 tires too wide for the rims?
Here's a short calculation I made:
Tire width: 255 mm
Rim width: 8.5 x 25.4 = 215.9 mm
=> tires are 19.55 mm (3/4") wider on each side of the rim.
It seems ok to me, but maybe the experts have a different opinion?
Thanks for your input!
Old Jan 15, 2007 | 07:43 AM
ren274u's Avatar
i have that size on my front and it looks fine.
Old Jan 15, 2007 | 07:52 AM
TillmanSpeed's Avatar
Former Vendor
255/45/18 should be fine. Anyone with a good tire mounting machine for aftermarket tires, and low profile applications should have no problems. On a regular tire machine, they're a pain in the ***!
Old Jan 15, 2007 | 08:51 AM
classj's Avatar
255-45-18 should be fine. That is what I am going to run on my polished bullitts when I am done with the factory bfg's.
But I would not go wider if you are going for cornering. To much tire squirm. Even the 255 is pushing it a bit but should be fine.
Old Jan 16, 2007 | 08:49 AM
jhue75's Avatar
I autocross and I stuffed 275 35 18's on a 18 x 8 Wedsport rim. The 18 x 8.5 should easily swallow a 255.
Old Jan 16, 2007 | 09:38 AM
dly's Avatar
dly
Got 265/40/18 BF Goodrich KDW on mine and they look good and run even better.
Old Jan 16, 2007 | 09:52 AM
Louie's Avatar
Thanks for the replies, guys!
I ordered the rims and tires, but I won't install them until the end of February, when it gets warmer.
14BlackGT
Aug 26, 2015 12:33 PM
whowasthat
Jul 19, 2015 01:49 PM
