Tire revolutions per mile
Old 5/15/07 | 10:30 AM
AirGoNomyk's Avatar
Where can I find info that will help me adjust the speedo to compensate for bigger tires? I had the 17in Pirelli (stock) and now I have 18 SSR with 255/45ZR/18 Goodyear F1s all the way around.
Old 5/15/07 | 10:34 AM
Knight's Avatar
Needs to be more Astony
well you could always do the math. calculate the circumference of the tire and and take a mile and divide it by that.
Circumference is pi x diameter.
Old 5/15/07 | 10:51 AM
theedge67's Avatar
www.tirerack.com will list revs per mile for each tire.
Knight's Avatar
255/45 is a 11.475 cm sidewall which converts to (4.5177 inches x 2) + 18 inch tire is diameter of 27.0354 inches x pi(3.14159265) = 84.9342 inches
1 mile = 63360 inches. / 84.9342 = 745.98 revolutions.
Old 5/15/07 | 11:44 AM
f1-cobra's Avatar
Bruce, I tried to do the same with mine. I adjusted it with the SCT Xcal2 (I think I used 745) and it seemed to mess up the speedo. I put it back to stock and it was fine. It's still set to stock with the Goodyears and it's dead on with the mile markers and speed traps.
Old 5/15/07 | 11:47 AM
AirGoNomyk's Avatar
Thank you very much Steve...that was what I needed to hear. The Tire Rack does not list the revs per mile for this tire.
Old 5/15/07 | 11:48 AM
Knight's Avatar
Originally Posted by AirGoNomyk
Thank you very much...that was what I needed to hear. The Tire Rack does not list the revs per mile for this tire.
didn't trust my math.
Old 5/15/07 | 11:56 AM
LBJay's Avatar
Plug the two tire sizes in at Miata.net Tire Size Calculator
I get only a 0.5% (742 vs 746) difference... no change necessary.
Old 5/15/07 | 09:06 PM
kevinb120's Avatar
I did 748 revolutions in the parking lot today on the way out of work, and its a small parking lot
Old 5/15/07 | 09:21 PM
bob's Avatar
bob
you can also visit the tire manufacturers website, In this case BFGoodrich publishes its tire data http://www.bfgoodrichtires.com/specs...-a-kdw/22.html (as an example)
RRRoamer
1/19/17 05:27 PM
dblhelx
12/29/15 04:16 PM
MustangMike94
8/15/15 09:42 AM
Quick Reply: Tire revolutions per mile
