Tire revolutions per mile
Old May 15, 2007 | 10:30 AM
AirGoNomyk's Avatar
Where can I find info that will help me adjust the speedo to compensate for bigger tires? I had the 17in Pirelli (stock) and now I have 18 SSR with 255/45ZR/18 Goodyear F1s all the way around.
Old May 15, 2007 | 10:34 AM
Knight's Avatar
Needs to be more Astony
well you could always do the math. calculate the circumference of the tire and and take a mile and divide it by that.
Circumference is pi x diameter.
Old May 15, 2007 | 10:51 AM
theedge67's Avatar
www.tirerack.com will list revs per mile for each tire.
Knight's Avatar
255/45 is a 11.475 cm sidewall which converts to (4.5177 inches x 2) + 18 inch tire is diameter of 27.0354 inches x pi(3.14159265) = 84.9342 inches
1 mile = 63360 inches. / 84.9342 = 745.98 revolutions.
Old May 15, 2007 | 11:44 AM
f1-cobra's Avatar
Bruce, I tried to do the same with mine. I adjusted it with the SCT Xcal2 (I think I used 745) and it seemed to mess up the speedo. I put it back to stock and it was fine. It's still set to stock with the Goodyears and it's dead on with the mile markers and speed traps.
Old May 15, 2007 | 11:47 AM
AirGoNomyk's Avatar
Thank you very much Steve...that was what I needed to hear. The Tire Rack does not list the revs per mile for this tire.
Old May 15, 2007 | 11:48 AM
Knight's Avatar
Originally Posted by AirGoNomyk
Thank you very much...that was what I needed to hear. The Tire Rack does not list the revs per mile for this tire.
didn't trust my math.
Old May 15, 2007 | 11:56 AM
LBJay's Avatar
Plug the two tire sizes in at Miata.net Tire Size Calculator
I get only a 0.5% (742 vs 746) difference... no change necessary.
Old May 15, 2007 | 09:06 PM
kevinb120's Avatar
I did 748 revolutions in the parking lot today on the way out of work, and its a small parking lot
Old May 15, 2007 | 09:21 PM
bob's Avatar
bob
you can also visit the tire manufacturers website, In this case BFGoodrich publishes its tire data http://www.bfgoodrichtires.com/specs...-a-kdw/22.html (as an example)
RRRoamer
Jan 19, 2017 05:27 PM
dblhelx
Dec 29, 2015 04:16 PM
MustangMike94
Aug 15, 2015 09:42 AM
