ticking noise at start up
Old Jan 3, 2008 | 08:09 PM
gpp's Avatar
gpp
when i crank my 06 gt it sounds like the lifters or something make a loud ticking noise for about 10 to 15 seconds.after the initial crankup it doesnt do it again until it sits up a few days.does anybody else have this problem and is it something to be concerned with if its just the lifters leaking down?
Old Jan 3, 2008 | 08:27 PM
theedge67's Avatar
It's either the lifters or more likely the timing chain rattling from no oil pressure. If the engine sits for a few days the oil can leak out of the oil filter, especially if you use an aftermarket filter with a non silicon anti-drainback valve. Always use a Motorcraft filter.
Old Jan 4, 2008 | 08:33 PM
JonCo's Avatar
Does it do it when you stop at a stop light? I had this problem happen. It turned out it was the cam followers which were bad. I had to firhgt for 2 months to get it fixed. Good as new now
Old Jan 4, 2008 | 10:58 PM
Stangers's Avatar
Sure its not the injectors?There loud on these new stangs.Do a search theres a thread on this issue from waaaaay back.
These motors dont have lifters.
Old Jan 5, 2008 | 10:00 AM
RRRoamer's Avatar
Tell me about it! While installing my WB O2 sensor, I fired up the car with the hood open and when I came back around to the front, I almost started swearing because it sounded like I had a nasty exhaust leak.
When I moved my head closer to verify that it was from the passenger side O2 sensor (the one I swapped out), I realized I was just hearing all those noisy fuel injectors clicking away.
They are loud little buggers!
Mpaps
Oct 11, 2017 08:06 PM
PonyMuscletang13
Sep 26, 2015 02:33 PM
khoy37
Sep 15, 2015 07:10 PM
jim010
Sep 7, 2015 02:40 PM
