Throttle Body Bypass Kit
Old Apr 2, 2007 | 02:55 AM
302svt's Avatar
Is anyone using this or even heard of it. Sounds like it makes sense but who knows.
http://cgi.ebay.com/ebaymotors/05-07...98526697QQrdZ1
Old Apr 2, 2007 | 04:32 AM
LimeGT's Avatar
A coolant line to the throttle body?!? I don't think that is correct for our cars.
Old Apr 2, 2007 | 06:19 AM
Hatchman's Avatar
Coolant does not flow through our throttle body.
Old Apr 2, 2007 | 11:09 AM
hawgman's Avatar
I emailed the seller just to see what his response would be.
"There are actually coolant lines running to and from the throttle body. They are being hidden by the air intake, so they are not easily seen. Thanks."
Odd, I have removed my throttle body a couple of times, and also removed the intake when I put the SC on. Never have I seen coolant lines running to and from the throttle body
Old Apr 2, 2007 | 11:23 AM
SlwSVT's Avatar
That is a old 5.0L trick we used to do back in the days. This seller figures for $11.95, that he would post it for more vehicles so he could make a buck. In his listing he says some or many vehicles have coolant running thru the throttle body. Cheap way of making a buck.
Old Apr 2, 2007 | 11:50 AM
Arrow's Avatar
Is this as retarded a concept as I think it is? Pumping coolant to the TB to cool the incoming air?
Although I bet the guy gets plenty of sales. We should all go down-rate the vendor for fun...
Old Apr 2, 2007 | 11:59 AM
SonicStang's Avatar
According to Scrming's website, he did this b/c the v6 tb has coolant running through it. He did a write up about it. He also showed that his inlet temperatures went down with this mod.
Old Apr 2, 2007 | 12:02 PM
Mongoose's Avatar
This is total BS in its purest form. LMAO
Old Apr 2, 2007 | 12:30 PM
DynamicmustangGT's Avatar
Watch out for this kind of stuff on ebay
Old Apr 2, 2007 | 02:00 PM
RedDragon777's Avatar
honestly i want to see what this guy says, i want them to send me detailed pics of this installed and everything, i have taken apart my intake and throttle body twice with no sign of lines
Old Apr 2, 2007 | 02:41 PM
isn't the throtle body on the s197 model electric? If so why wouls you putfuid near the electrical components?
Old Apr 2, 2007 | 03:25 PM
G.T's Avatar
G.T
This is plain retarded.
as all of you have figured, this kit isn't for a S197..
notice the dyno sheet is from a 99 Camaro
Old Apr 2, 2007 | 07:43 PM
281GT's Avatar
This is pretty misleading. They are absolutely correct that some vehicles do have a throttle body heater that uses coolant but the 05+ Mustang GT does not have this therefore it does not apply. The seller needs to remove the reference to our cars in his advertising.
Old Apr 3, 2007 | 02:06 PM
Mustang05's Avatar
Actually our stangs came with a heater type deal. To prevent the throttle body from freezing. I dont know if they stopped one year but i know mine has them and others as well.
http://www.v6john.com/Main/Performan.../tb_bypass.htm
Old Apr 3, 2007 | 02:17 PM
black sunshine's Avatar
If you belive that then I have a nice new set of muffler bearings that I can sell you too.
Old Apr 3, 2007 | 02:20 PM
Mustang05's Avatar
Dude. I posted the evidence of the lines... I think ford either just used them in the V6 or they stopped using them after sometime.
Old Apr 3, 2007 | 03:37 PM
garyb900's Avatar
There are coolant lines running to the TB on the 2005 V6.
This seller is being misleading since the GT doesn't have it. ONLY THE 2005 V6.
I have a 2005 V6 and it does have casting in the throttle body for coolant to run around it so that in severe cold weather it gets heated so that the butterfly does not stick.
I ran my bypass with a short piece of heater hose before winter and never had a problem with the TB.
I don't think the coolant is needed as all it does is heat the air going into the intake causing power loss.
http://www.mustangcollective.com/showthread.php?t=3329
Old Apr 3, 2007 | 06:33 PM
281GT's Avatar
I was not aware that the V6 cars had this. Certainly on those cars it is worth doing. I'd also like to point out that this mod will not cause any icing problems in the winter as I did this to a previous car I had and drove it through many harsh Canadian winters with no issues whatsover so if you V6 guys want to do this you can go ahead and do it with no concerns about icing in the throttle body.
Road_Runner
Sep 2, 2024 04:46 PM
09-gt/cs
Oct 15, 2015 10:03 AM
GLOCKer
Sep 28, 2015 05:20 PM
