Those with MTs and 3:31s (drag racing)...
Old May 10, 2008 | 02:06 PM
GOarmy08's Avatar
How are you launching? What are you 60-ft times? Do you have drag radials?
I've gone to the track on 2 seperate occasions and found it pretty hard to find the sweet spot which to launch this combo at. Here are two examples...
Good launch, with tire spin. 1.879 60-ft time
Bad launch, with bog. 2.0xx 60-ft time.
I'm just wondering how anyone else is doing this... I'm launching anywhere from 4-5,500 and most of the time if it's 4,500 and below it bogs hard.
Old May 10, 2008 | 02:14 PM
GOarmy08's Avatar
I also realize that this post has a lot of factors you're probably wondering about to make a good analysis, but just ask me I check this pretty often. I don't have much time right now though.
Old May 10, 2008 | 03:55 PM
70MACH1OWNER's Avatar
I didn't know you could get a manual trans with 3:31 gears. Is that something new for 08? I have an 05 auto with 3:31 gears and couldn't figure out how you were launching at 4500-5000 rpm.
Scott
Old May 11, 2008 | 01:10 AM
GOarmy08's Avatar
I believe it was new for 07... 3:55s were an option... I custom ordered my car from Iraq and chose not to have the 3:55s because I planned on 3:73s/3:90s in the future anyway.
Old May 14, 2008 | 10:42 AM
Rebel73's Avatar
yep. 3:31s are standard since 07...
Old May 16, 2008 | 01:30 AM
GOarmy08's Avatar
any other tips from other short gear drag racers? lol.
Old May 16, 2008 | 05:26 AM
DarkFireGT's Avatar
I'm having the same bogging issue as well with my M&H's and 3:31's. No spinning here. The M&H's with a good burnout hook right up. And it goes so fast, I don't remember if I'm dumping the clutch or slipping it. I guess I need to pay more attention to that. 2.0 60's is all I'm seeing right now. Though, I'm about to pull the trigger on a 2 step. So I know that will help.
Old May 16, 2008 | 05:20 PM
travelers's Avatar
Try and just do a clean off of the tires and don't heat them up. When are you planning on changing the gears?
Old May 16, 2008 | 08:37 PM
GOarmy08's Avatar
Darkfire, that sounds like when I slightly slip the clutch... Best I've done with a little slip action is a high 1.9 60.
travelers, actually the 1.8 60 came from doing a short burn out (compared to the 2nd vid)... so I'm guessing that's what I'll be doing my next time out.
Old May 16, 2008 | 09:03 PM
DarkFireGT's Avatar
I was getting 2.1 the first couple of times. I did a longer burnout and got a low 2.0. I've got my wheel balance issue fixed (BOTH wheel weights had fallen off) so hopefully I can get back to the track in the next couple of weeks and get those 60's below 2.0. Next mod is definitely the new MSD 2 Step Limiter. I'm not opening my rear end until I hit 12's. That's my goal. I may not have the money to set speed records, but it'd be nice to say I hit 12's with bolt-ons and 3.31's.
AdPock
Oct 16, 2015 02:58 PM
Sep 30, 2015 07:02 PM
RoushRS3
Sep 29, 2015 08:03 PM
southern stang
Sep 26, 2015 04:19 PM
