There's a bolt in my tire!
Yesterday I must have ran over a big bolt because this morning my tire was flat to the rim I'm not sure if they will be able to patch it, do u guys no where I can order a new tire to mach the rest of my stock tires??? I looked on www.tirerack.com but the tread design isn't the same. THANKS Kevin
I had to go to the dealer to get a replacement. $178 for the tire + install. Plus it took a week to get there.
Originally posted by acadian@April 15, 2005, 1:00 PM
Yeah, use this as an opportunity to get 255's all the way around. Or, at least in the rear right now.
You can get a replacement Parelli from Discount Tire. I had to buy one when I ran over a piece of freeway junk. If you can afford to toss 3 good tires to change brands/size, it's your choice. I found it much more economical to just buy the 1 tire. After 25-30,000 miles I will then consider my tire options.
