Summit Racing offroad H...
I installed it today, and it seems to be smoking a bit (coming out of the axleback). It seems there was this greasy stuff all over the H pipe that it must be burning off. Anyone else witness this?
Some kind of coating on the inside that burns off gradually.. I had the same thing on my Pypes H. Should burn off eventually.
Alright cool. Another question...my axlebacks are a bit off now. I knew, there was a good chance they would move, and know how to correct it, but it is not working. I made sure the h pipe was slightly loose and had someone hold the axlebacks center while I tightened. The driver's side is fine, but the passanger side is just hanging about 1/2 inch too low.
Location: New Carlisle, Ohio (20 miles north of Dayton)
The smoke from a new H-pipe is normal. They also use a lubricant to bend the pipe bender. It is normal. Sounds like you just need to loosen the midpipe clamp and readjust the passenger side. It takes a couple of trys some times.
Scott
when i had my summit racing h-pipe put on with my flowmaster axle backs they were a bit off until i had him weld the center H crossover cause it was leaking and had him center it but it looks really good now heres a pic.....
it was actually the mufflers them selves and the right one was perfect just the left one was too much towards the center of the car but my buddies shop that put them in said he mad them fit perfectly center but i dident ask how.... probably bend the hangers maybe?
After installing my MRT H pipe, it took me forever to get the Hooker Aerochambers aligned right
you just need to loosen the midpipe clamps and the axleback clamps and play around with adjustments - really helps to have a second set of hands. Keep that up though and you'll get ti fixed.
