street traction with twin screw blower
Old Jan 25, 2008 | 08:12 PM
gpp's Avatar
gpp
those of you with twin screw blower and automatic transmission at about what gear and speed will your car have to be at to not spin with full throttle?my lightning has to be at about 4000 rpm in 2nd gear before i can kick it without spinning.i know its lite in the rear but i was hopeing the mustang wouldnt be so bad.would getting a paxton,procharger or vortech be easier on spinning than the twin screw enough so to buy it over the twinscrew?
Old Jan 25, 2008 | 08:34 PM
SONICBOOST's Avatar
I have a paxton and I still spin in first gear, it will want to break loose in second sometimes . I also have a manual though...
Old Jan 25, 2008 | 09:19 PM
psfracer's Avatar
Depends on what tire you run and your suspension. With me, on the street, the Nitto 555's 295/45/18's are hopeless 1st and 2nd. With M&H drag radials, they spin only in first from a dead stop or like 15mph or less. Big difference.
If you want to run a typical street tire, and not spin, then the twinscrew is not for you.
Old Jan 26, 2008 | 06:27 AM
tom281's Avatar
Not questioning Paul's input at all, but just adding that although yes he is running a TS blower, he has probably around 100 more hp & tq than the typical TS setup. That would have to make the traction game more difficult than standard setups to some degree.
Old Jan 26, 2008 | 06:38 AM
gpp's Avatar
gpp
i was looking at about 425 at rear wheels or a little less.i like the torque the ts has down low but if you cant do anything but spin till you get to say 40 mph its not much use.tried drag radials on my lightning but didnt help but differant vehicle,no weight in rear.
Old Jan 26, 2008 | 07:30 AM
Hatchman's Avatar
I also have an '04 Lightning. I usually run Nitto 555 295/45 on it and the rear of the Mustang. Both cars will blow them loose pretty easily in first and second. I put some Nitto 555 DRs on the Lightning and the traction is much better, but they wear about twice as fast and feel a little looser in the corners due to the flimsy side walls. But like said, you're going to blow street tires loose pretty easily with a TS, but the instant torque when you need it is worth it.
Old Jan 26, 2008 | 10:16 AM
max2000jp's Avatar
I have little traction issues on the street with my Vortech. It's all in the tires you choose.
Old Jan 26, 2008 | 10:30 AM
SONICBOOST's Avatar
What tires do you use because I have problems with first sometimes ( most of the time). I usually have to shift at 4-5k at wot on first.
Old Jan 26, 2008 | 10:50 AM
max2000jp's Avatar
275/40/18 Bridgestone RE050A Pole Positions. I've also got CHE LCA's and UCA.
Old Jan 26, 2008 | 03:39 PM
GOarmy08's Avatar
I don't have a twin screw, but I can still blow the tires up through 1st rolling on the throttle, and up to 60-65mph in 2nd depending on how I shift. lol.
Old Jan 26, 2008 | 06:06 PM
2kanchoo's Avatar
Yea if I drop the clutch off the line with the stock all seasons I spin through the first 3 gears and chirp 4th so with another 100rwhp+tq yikes...
Old Jan 28, 2008 | 06:17 AM
05YellowGT's Avatar
I have 285/35/19 Falkens on the rear and even from a slow roll I have to let off in both first and second or the rear will fish tail ...
Old Jan 28, 2008 | 08:53 PM
anthony05gt's Avatar
With my twin screw and 4.10 gears I could downshift from 5th to 4th at 75 mph aggressively and just light the tires up and fishtail badly. Had to let off the gas. I put my 3.55's back in and it tamed it down a bit. I wouldn't trade my twin screw for another. Bottom end torque is just too good and it still pulls to redline!
Old Jan 28, 2008 | 09:06 PM
SONICBOOST's Avatar
How is it going wot in first and second? Any spin?
Old Jan 28, 2008 | 10:07 PM
SlamMan02's Avatar
LOL That excites and scares me at the same time..
Old Jan 28, 2008 | 10:13 PM
Torrence's Avatar
Hit the gas to hard and you'll be like a fish in the ocean..... Fish tailing..... Fun though....
Old Jan 30, 2008 | 09:27 PM
You can't be serious. I have no WOT in first, second, and I sometimes have to let off the gas while hitting third gear to avoid fishtailing with street tires and my re-installed 3.55 gears. 4.10's had to go.
Old Jan 31, 2008 | 01:03 PM
65sohc's Avatar
Sounds frustrating. As an editor of Car and Driver once said, "It's more fun to drive a slow car fast than a fast car slow."
Old Jan 31, 2008 | 09:08 PM
SONICBOOST's Avatar
Dam!, What #s are you putting to the ground?
dblhelx
Oct 6, 2015 08:08 PM
MustangGTCS13
Sep 17, 2015 07:38 AM
Sep 16, 2015 06:44 PM
Sep 8, 2015 10:45 AM
