Stock shocks with eibach pro springs
Old Jul 17, 2007 | 05:40 AM
The eibach springs drop the rear 1.4 inches. Would that be the out side edge of the stock shocks use ability. The reason I ask is when I hit a larger bumps it sounds like my rear end is going to fall off, or is it that my shocks just bottoming out? I have cut all but the bottom nub on the bump stops. Should I just remove them all together. Should I have left them in tact and not cut them at all?
Thanks in advance for any help.
Old Jul 17, 2007 | 06:29 AM
blkstang06's Avatar
Glenn I'm running Ground Force performance springs 1.4'' drop in the rear 1.3'' in the front , I still have the factory shocks and struts on! until I have time to put my Tokico HP's on. I have never cut my rear bump stops! I chalked the top of the bump stops to see if they would make contact and I have intentionally ran on really bumpy roads so far no contact! but I have noticed a lot of slop in the factory dampers! and of course rattling from the junk front factory strut caps, I got a set of GT 500 caps to replace them with when I install the new dampers. So put it this way the rear sound and responds just about like it did before the drop, but the front sounds like rattling popping piece of **** !!
Old Jul 17, 2007 | 10:40 AM
MooStang05gt's Avatar
Glenn... I used the OEM dampers with my Ground Control Coil-over Conversion Kit with Eibach Sport Springs for a while and the OEM dampers are prone to bottoming out.. they are just to long for lowered cars... my car is currently set at 1.25 front and 1.3 rear... I cut the rear bump stops down to 1" height.
You will probably have the noise and a harsher ride until you go to a shorter damper set. Going to the FRPP dampers make a lot of difference in the ride quality over the OEM dampers.
Bobby M.
Old Jul 17, 2007 | 09:14 PM
RadBOSS's Avatar
The way this (and other) car is designed, the shock or the strut will not bottom out. If they were to, their life is usually short lived because they can not withstand that kind of treatment.
When you lower your car you reduce the bump travel. A 1.5" drop eats up nearly 50% of your stock bump travel! You compenstae for the less bump travel with higher rate springs and higher rate damping. The higher rate damping also serves to control the higher rate springs.
Old Aug 9, 2007 | 12:48 PM
found one of my sway bar links came loose I didn't replace the nuts like I was supose to. That helped a lot. I can say for sure don't drop it more than one inch with out changing shocks and and struts..... and heck if you can swing it get them even if your droping it an inch. You won't be sorry!
dohc97
16
Sep 24, 2015 05:40 PM
MRGTX
Aug 21, 2015 08:49 PM
dohc97
17
Aug 14, 2015 07:12 PM
ToddMcF2002
'10-14 Exterior Modifications
17
Aug 3, 2015 07:42 PM
killaz05
Jul 24, 2015 08:49 AM
