Stock 2005 5spd GT dyno numbers inside
Old 10/28/04, 08:30 AM
Avenger's Avatar
Modular Powerhouse thread
279 rwhp / 300 rwtq B)
Air / fuel ratio is so rich they expect 300 rwhp after a dyno tune
Old 10/28/04, 08:35 AM
gotmy05's Avatar
thats awsome!!!!
Old 10/28/04, 08:41 AM
MTAS's Avatar
Holy SMOKES!!!! That's 328hp/352tq at the fly. Yeah, that's a "robust" 300hp alright (to quote one of the Ford engineers) :worship:
Old 10/28/04, 08:51 AM
new22003's Avatar
Wow thats fantastic. Tims a good guy and I look forward to great things from modular ford powerhouse with the 2005.
97svtgoin05gt's Avatar
That's awesome stuff.
Can't believe some poster on that board actually doesn't like the body style.
Can you say Pearle Vision Center??
Old 10/28/04, 08:54 AM
I Have Admin Envy
Galaxie's Avatar
best quote from that forum
This 3 valve just put down more stock then any Mach1 I've dyno'd stock
Old 10/28/04, 08:55 AM
MrMorden's Avatar
Sounds like 320rwhp with just a tune, pulleys, X-pipe, and maybe a couple of other bolt-ons.
Thank you Ford Motor Company!
Old 10/28/04, 09:09 AM
clintoris's Avatar
sounds like 472 hp at the flywheel, 423 rwhp is just 8 lbs of boost away
Old 10/28/04, 09:50 AM
Dan
Do You Remember Me?
Dan's Avatar
Wow....and that was at 211 miles.
Evil_Capri's Avatar
Great numbers!
Very cool!!
Old 10/28/04, 02:12 PM
WBstangGT's Avatar
Sweet, can't believe I missed this post. That is awesome, Ford tuned em running rich... that is awesome for the typical bolts ons. Might be pushing 330 with very lil in expenditure. Not to mention that reflash of the cpu should put it over 350 easy.
Old 10/28/04, 02:23 PM
Wolfie351's Avatar
Peak hp is nice, but I want to see the torque curve. See how much that variable valve timing helps down low.
Old 10/28/04, 02:26 PM
gendronj's Avatar
So coming out of the factory they need to be re-tuned? How much does that cost to have that done, and why wouldn't the factory have these machines running correctly from the beginning?
Old 10/28/04, 02:53 PM
grrr428's Avatar
They are running "correctly" for a wide range of applications, situations and drivers. That's why people "tune" their cars for specific situations: RACING usually!
Old 10/28/04, 03:34 PM
kevinb120's Avatar
If thats on mustang dyno, the numbers are acually even higher :shock:
Old 10/28/04, 03:53 PM
Shea's Avatar
Here's a link to the pic of Motor Trend's dyno chart and numbers.
http://forums.bradbarnett.net/upload...1096325116.jpg
They got lower numbers than this thread states. Also, on their dyno chart it appears that this model will NOT have the torque down low.
Unfortunately, they do not chart the entire RPM range, but more than likely this 3V engine will need to be wound up to 4K to produce serious power.
That is a drawback of a modular engine.
Also, I don't understand why they would make this engine run rich from the factory. Usually cars run lean from the factory to keep emissions down and gas mileage up.
Old 10/28/04, 03:54 PM
Dr Iven's Avatar
I think we've established now that this car is the best bang for your buck on the road.
Old 10/28/04, 03:55 PM
ZERO's Avatar
:worship:
Old 10/28/04, 04:26 PM
willy_sc5.0's Avatar
DYNO 05 GT(blue) vs Mac 1 04(red)
http://www.corral.net/forums/attachment.ph...tid=39122&stc=1
Old 10/28/04, 04:55 PM
lordserb's Avatar
So I'm new to the whole tuning thing, so could someone give me the down and dirty explanation of how i could tune up the GT for cheap?
Quick Reply: Stock 2005 5spd GT dyno numbers inside
