Steeda UDP puller?
I put mine on last sat. To put them on your gonna need a breaker bar to pull the tensioner to get the belt off. I forgot what size the water pump pulley bolts were, and an 18 mm socket to get the bolt for the crank pulley off, and some silicone to put in the key slot for the crank pulley. Also your gonna need a pulley puller to get the crank pulley off. I didn't have one (what a pain)so i had to wedge it off with 2 long screwdrivers and a hammer. I had no idea what i was doing but its a real easy install the only problem I had was with the water pump pulley. there was a bolt sticking out of the motor that was right on the pulley and wouldn't let it turn, I just cut it with a wizard.
Originally posted by tmcolegr@May 18, 2005, 9:10 AM
You will need a 3-jaw puller and a torque wrench to do the job properly.
is there a specific size 3 jaw puller that is needed i understand it is an odd size...not the same as previous years.
"I didn't have one (what a pain)so i had to wedge it off with 2 long screwdrivers and a hammer. I had no idea what i was doing but its a real easy install the only problem I had was with the water pump pulley."
I hope that you were joking
9/24/15 08:15 PM
9/16/15 06:44 PM
9/10/15 12:44 PM
