Steeda UDP puller?
Old May 18, 2005 | 08:45 AM
adnlyn's Avatar
What tool exactly do i need to put on the Steeda UDP. I heard that a special tool is required what exactly is it? thanks
Old May 18, 2005 | 09:03 AM
CAL05GT's Avatar
I put mine on last sat. To put them on your gonna need a breaker bar to pull the tensioner to get the belt off. I forgot what size the water pump pulley bolts were, and an 18 mm socket to get the bolt for the crank pulley off, and some silicone to put in the key slot for the crank pulley. Also your gonna need a pulley puller to get the crank pulley off. I didn't have one (what a pain)so i had to wedge it off with 2 long screwdrivers and a hammer. I had no idea what i was doing but its a real easy install the only problem I had was with the water pump pulley. there was a bolt sticking out of the motor that was right on the pulley and wouldn't let it turn, I just cut it with a wizard.
Old May 18, 2005 | 09:07 AM
tmcolegr's Avatar
You will need a 3-leg puller (OTC #1026 or Sears item #00946906000) and a torque wrench to do the job properly.
Old May 18, 2005 | 10:19 AM
adnlyn's Avatar
Originally posted by tmcolegr@May 18, 2005, 9:10 AM
You will need a 3-jaw puller and a torque wrench to do the job properly.
is there a specific size 3 jaw puller that is needed i understand it is an odd size...not the same as previous years.
Old May 18, 2005 | 11:03 AM
tx2005gt's Avatar
"I didn't have one (what a pain)so i had to wedge it off with 2 long screwdrivers and a hammer. I had no idea what i was doing but its a real easy install the only problem I had was with the water pump pulley."
I hope that you were joking
Old May 18, 2005 | 08:17 PM
CAL05GT's Avatar
Unfortunatly I'm serious.
Old May 19, 2005 | 08:46 AM
adnlyn's Avatar
thanks
Sep 30, 2015 07:02 PM
GeoWett
Sep 30, 2015 06:40 AM
Sep 24, 2015 08:15 PM
Sep 16, 2015 06:44 PM
Sep 10, 2015 12:44 PM
