Steeda Street/Strip Lower Control Arms
Old Jan 6, 2005 | 02:31 PM
dhof303's Avatar
Just installed Steeda adjustable lower control arms with urethane bushings, they work great. They install easily in about 30 minutes and are easily adjustable. I set them to the factory length (18.5") center to center of mounting bolt holes. Prior to installing new tires I had pretty bad wheel hop, after better tires it was insane. Enough to shake your teeth out during a hard launch. Now there is absolutely no wheel hop and the car launches straight and predictably at any RPM wether at a stand still or from a roll. Much easier install than the control arms on my 02 GT.
Sorry for the previous post, forum administrator deleted the wrong thread.
Old Jan 6, 2005 | 04:22 PM
ZERO's Avatar
k...can't wait to see the pics.
Old Jan 7, 2005 | 06:47 AM
Kluski's Avatar
Made the picture a little smaller
Old Jan 7, 2005 | 10:55 AM
RRRoamer's Avatar
Did you have to fine tune them to elimenate the hope, or just dial them in to the stock length and go? From what I have heard so far, I would think they would need to be a tad bit longer than stock to get a slght negative pinion angle...
Old Jan 8, 2005 | 10:12 AM
smitty's Avatar
How much more road noise do the urethane bushings transmit into the car verses the stock pieces? I was thinking of adding the billet pieces to my car when it arrives, but wouldn't want to degrade the refinement of the new car.
Old Jan 8, 2005 | 06:27 PM
dhof303's Avatar
I haven't noticed any more road noise than the factory control arms, I do however feel a slight difference in road feel. Road feel difference is for the positive, I can feel the road more and now can anticipate what the car will do. As for the adjustment I just placed them at factory length, I have plans to check the pinion angle later and look for a negative 2.5 degree angle. I want to have a baseline launch at the dragstrip with the current setting just in case it happens to be the magic number for the settings I want. For now it works awesome on the street, though any change from the factory would have been better.
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
robjh22
Sep 8, 2015 12:31 PM
Sep 8, 2015 10:45 AM
