Steeda Pullies install on Automatics
Old Jul 5, 2005 | 08:54 PM
Fman67's Avatar
Anybody here with an automatic gt do the underdrive pullies swap? Did you remove anything to get at them...instructions say from under car...no way your gonna get anything in ther big enough to turn that crank bolt.Any how to tips? Thanks
Old Jul 5, 2005 | 09:33 PM
BrownBrosPerf's Avatar
I do it from the top, I remove the cooling fan and move the coolant res and power steering res to the side. Then 3 jaw puller.
Old Jul 5, 2005 | 09:34 PM
JST4FN's Avatar
I did mine myself, but I do not remember all the details. I broke the bolt loose from the top and I have a strap that keeps the tranny locked. Basically you pull the access cover to the torque convertor. You remove one nut(on the convertor) and the strap mounts between the open stud and one of the access cover bolt holes. This locks the motor and tranny and the rest is up to you.
Thanks Mike
Old Jul 5, 2005 | 10:25 PM
Fman67's Avatar
How did you break bolt loose...air tools? How did you keep motor from turning?
Old Jul 5, 2005 | 10:26 PM
Fman67's Avatar
What strap you have? Where do you get such a tool? Thanks
Thanks Mike
Old Jul 6, 2005 | 06:05 AM
elvism's Avatar
i have it but didnt install it, sorry
Old Jul 6, 2005 | 11:38 AM
acadian's Avatar
I got the MMR Pulleys, which I assume are basically the same thing. I did it from the top, as per the directions.
ustabawannab
Aug 5, 2015 08:32 PM
Ecoboost
Jul 25, 2015 06:32 PM
Jul 21, 2015 08:08 AM
Jul 20, 2015 02:49 PM
Jul 20, 2015 02:47 PM
