Steeda Pulleys installation question
Old Dec 14, 2005 | 12:43 PM
Nick85's Avatar
About how much should I expect to pay to have these installed? Also about how long should it take?
Nick
Old Dec 14, 2005 | 12:44 PM
KWMJ-KTP's Avatar
Nick
When I checked around, I was getting quotes between $80-$96 dollars for installation, and about 1-2 hours install time.
I ended up putting them on myself, and it wasn't too bad.
Old Dec 14, 2005 | 01:13 PM
MaverickMLFD371's Avatar
$80, 1 hour-1 1/2 hours
Old Dec 14, 2005 | 05:58 PM
Nick85's Avatar
Thanks guys.
Old Dec 14, 2005 | 06:10 PM
Idrvadodgstr8us's Avatar
did you rent a pulley puller?
Old Dec 15, 2005 | 04:24 AM
KWMJ-KTP's Avatar
I did rent one from Autozone, but it was way too big to fit into the space you have. They gave me one that I think was a 9" puller. My grandfather had a few of them, so I used his instead. Can't remember if I used a 3" or a 4" puller, but it worked very well.
Old Dec 15, 2005 | 05:21 AM
haha gotta love the old schoolers...always have some kind of tool ya need...
Old Dec 15, 2005 | 06:12 AM
the guy that did it had 2 types of 3 prong pullers, and none of them worked cause the pulley didn't have drilled threaded holes in them at all, so we used 2 small thin crowbars and lightly/gently pryed the pulley off.
Old Dec 15, 2005 | 04:33 PM
70MACH1OWNER's Avatar
Autozone has the proper puller in the kit you can rent. You should pull the stock pulley from the inside of the steel hub and not on the outside diameter of the pulley. The stock pulley has a rubber damper and you can pull it apart if your not careful. The slots in the back of the stock pulley is what you pull on.
Scott
Old Dec 15, 2005 | 11:02 PM
Stoenr's Avatar
Great input. Will help many others
I love this website. Has soooo much to offer. Better than calling the products 800 # for tech support!
Jim74656
May 1, 2023 02:15 AM
ustabawannab
Aug 5, 2015 08:32 PM
Jul 30, 2015 06:47 AM
Ecoboost
Jul 25, 2015 06:32 PM
