steeda panhard bar adjustment?
Old Aug 31, 2007 | 09:07 PM
YaoNYC's Avatar
hi all,
how exactly is the panhard bar adjusted?
is it the rear left bolt or rear right bolt?
my rear right bolt got loose for some reason only after like 1000 miles and there was this annoying rear clanking that took many hours to find!
at times, i feel like screaming at the shop that installed it. this shop is a mustang shop too. so hard to find too quality help....
thanks all!
Old Sep 1, 2007 | 04:56 AM
tom281's Avatar
It's both bolts.... they are there on both ends so you can adjust it more easily in either direction.
I will say though, that my Steeda panhard was a pain in the ***...... although the flexibility of adjustment was nice, I could not get it tightened while on the car. I had to adjust it off the car, install it to make sure it was right, then remove it & tighten it, and finally reinstall it. BUT, its been on for several months now with some fairly hard street abuse and one trip to the track (probably about 6 runs) and it is still tight with no rattles, etc.
Good luck!
Old Sep 1, 2007 | 12:46 PM
blkstang06's Avatar
Good luck!
I don't think any of the adjustable PH bars are easy to adjust! but I didn't have remove the J&M I installed to set the jamb nuts but the passenger side is a fother mucker to get to!!.......
Sep 30, 2015 07:02 PM
GeoWett
Sep 30, 2015 06:40 AM
RoushRS3
Sep 29, 2015 08:03 PM
AJ_Trevino15
Sep 28, 2015 07:51 AM
Sep 24, 2015 08:15 PM
