Steeda High Flow Inlet Elbow?
Old Oct 30, 2006 | 04:35 PM
TorchRedV6's Avatar
Does anybody know if this works with other CAI's than Steeda or is it just for their intake? Saw it in a magazine and it said it gains 8hp. If it works with other CAI's I might get it. I have the JLT intake.
Old Oct 30, 2006 | 04:59 PM
m05fastbackGT's Avatar
I don't know if both inlets are the same size ? or if the intake for the GT is larger so you should contact Steeda Tech support and ask them if it would work, sorry I couldn't be more helpful..
Old Oct 30, 2006 | 06:08 PM
65sohc's Avatar
Since you already have a JLT there would be no point. The original Steeda CAI uses the smaller diameter stock Ford inlet tubing. The new Steeda elbow replaces that tubing. It is interesting to note that when I was shopping for CAI's 6 months ago I asked a Steeda tech whether there was any disadvantage to using the original tubing since almost all the other aftermarket CAI's use their own designs. He told me that Steeda had done extensive testing and found no horsepower loss associated with the standard tubing. Now they have jumped on the bandwagon and suddenly discovered 8 hp.
Old Oct 30, 2006 | 07:19 PM
And your point is ? First off, Steeda designed the intake elbow exclusively for their CAI because customers requested it, and not because of jumping on some bandwagon..
Old Oct 30, 2006 | 07:40 PM
spyder7724's Avatar
you can also buy the inlet pipe from c&l but it's like $170 just for the cast aluminum pipe.
Old Oct 30, 2006 | 07:45 PM
the Steeda inlet can be purchased for $107 shipped, it may not be as nice as the C&L cast aluminum inlet but it's much less expensive..
Old Oct 30, 2006 | 10:13 PM
Jon_Purdy's Avatar
I'd like to have the Steeda heat shield for my C&L intake. The C&L heat shield is pretty flimsy. At high revs, it vibrates like you wouldn't believe.
Jon
Old Oct 30, 2006 | 10:33 PM
Hi Jon ? did you know C&L upgraded their heat shield ?? from what I understand the new shield is supposed to be thicker and not nearly as flimsy as the old one..I don't know if it's on their website yet or not, but if you don't have the new shield ? you ought to give Lee at C&L a phone call and see if he can work something out with you..Anyway, good luck to you..
Old Oct 30, 2006 | 10:56 PM
65sohc's Avatar
Apparently their customers knew something that Steeda didn't, namely that half a CAI isn't as good as a whole one. When they didn't have an inlet elbow to sell they claimed they did no good. Now that they offer one, freer flowing elbows apparently do work.
Old Oct 30, 2006 | 11:05 PM
That's another reason why I like Steeda, it's because they listen and care about their customers needs and I can say with confidence that it really performs well and haven't run into any drivability problems, no check engine lights or anything, not that I'm trying to say the other's don't listen to their customers, I'm just pointing out my personal experiences with Steeda which have all been nothing but positive ones..
Sep 30, 2015 07:02 PM
GeoWett
Sep 30, 2015 06:40 AM
Sep 24, 2015 08:15 PM
