Steeda or Eibach lowering springs
Old Feb 7, 2005 | 03:43 PM
NickS's Avatar
I'm planning on getting Steeda lowering springs this spring for my 05 GT. I know the springs sell for 260 on Steeda's website, but how much does the installation usually cost? Also, where did most of you get your's installed? Thanks guys.
Old Feb 7, 2005 | 06:00 PM
steal101's Avatar
I paid 175.00 for the install and 199.00 for the Pro Kit. Take it to a place with a good rep.
Old Feb 7, 2005 | 08:47 PM
zee's Avatar
zee
HEY DID U GUYS CHANGE THE SPRINGS AND THE DAMPERS OR JUST THE SPRING, AND IF JUST THE SPRINGS IS THAT GOOD FOR THE RIDE.
THANKS
Old Feb 7, 2005 | 09:00 PM
steal101's Avatar
Just the springs and the ride is almost the same.
Old Feb 7, 2005 | 10:04 PM
Mongoose's Avatar
Please tell me where you purchased for that good price. Thanks
Old Feb 8, 2005 | 08:46 AM
Mellow Yellow's Avatar
Sorry for the silly question, but aren't springs pretty easy to install? I don't mean that you can just install em in a few minutes in your garage, but more that any decent performance shop should be able to do it? I am getting springs done soon as well, but the local shop with the best rep in town for working on stangs is literally over an hour away. I will be going there for any tunes and gears and such, but I was thinking that the performance shops nearer to me could handle something like springs. Am I wrong for thinking this?
Old Feb 8, 2005 | 10:00 AM
DozerzPony's Avatar
Good question!!! I am in the same boat.
Old Feb 8, 2005 | 11:10 AM
adrenalin's Avatar
Rear springs are very easy to replace as long as you have 2 jack stands and a floor jack. The front ones are harder as you need to remove the strut and you also need a spring compressor. However, that being said a lot of places rent spring compressors. When I get a kit I will install it myself. It will take about 1 hour for each front spring and maybe 1 hour for the rear.
Old Feb 9, 2005 | 07:52 AM
DozerzPony's Avatar
Thanks for the info. So rent a spring compressor and if a have a standard set of wrenches, I am good to go?
Old Feb 9, 2005 | 08:02 AM
After doing a bit of research, I personally won't be attempting this myself. Decompressing, and recompressing the springs, even with a spring compressor is a very dangerous thing to do, and if the compressor, or your floor jack fails it can have pretty serious results. The load on these compressed springs is pretty large, and rapid decompression due to a failure in a piece of equipment can cause serious injury.
Old Feb 9, 2005 | 12:44 PM
DozerzPony's Avatar
I am with you. Screw it, I am paying to have it done. Too much uncertainty in this forum. Go with the safe alternative. Thanks.
Old Feb 9, 2005 | 03:27 PM
DeathMonk's Avatar
Originally posted by DozerzPony+February 9, 2005, 1:47 PM--><div class='quotetop'>QUOTE(DozerzPony @ February 9, 2005, 1:47 PM)</div><div class='quotemain'><!--QuoteBegin-Mellow Yellow@February 9, 2005, 7:05 AM
[/b][/quote]
I did it on my 66 mustang. I had some cheap spring compressor from autozone and the spring popped out of it. luckily, nothing happened. I ended up getting a compressor that goes through the spring instead of on the side. Was pretty easy then.
Old Feb 9, 2005 | 09:00 PM
acadian's Avatar
If you get a good spring compressor and know how to use it and use it right, you should have no problem with doing it yourself. Spend a few hours and do it yourself... just make sure to take your time. If I get springs, which I'm still not sure about, I will be doing it myself. Just make sure you research the install and how to use the compressor beforehand.
Old Feb 9, 2005 | 10:23 PM
O5GT's Avatar
what about alignment issues and panhard rod ?
anything need to be done there?
thanks in advance
Old Feb 10, 2005 | 08:35 AM
DozerzPony's Avatar
Alignment is a M U S T !!!
Old Feb 10, 2005 | 09:03 AM
dtoups's Avatar
local speed shops have quoted $475 to $550 including alignment (race alignment for autocross). think i'll be doing it myself ...
Old Feb 25, 2005 | 04:11 PM
2005MustangGT's Avatar
Just figured I would let you know, that I'm lowering my 05 tomorrow...not using aftermarket springs though.....gonna "CUT" em.
-I know, I know....everyone thinks that is a bad idea, but I'll be the guiena(spelling) pig for everyone else.
Old Feb 25, 2005 | 04:46 PM
adrenalin's Avatar
I just installed Eibach pro-kit springs today. Only took me 1 1/2 hours. Ride is a bit stiffer but not that noticable. I like the feel and the new look
Old Feb 25, 2005 | 04:47 PM
adrenalin's Avatar
Cutting is never a good idea Trust me, you will regret doing it just like everyone else. If you don't cut them right you will have popping noises. If you do cut them right you will be bottoming out a lot anyway.
Old Feb 25, 2005 | 05:14 PM
Adrenalin???
did you have to use any special spring compressor on the front?
I've installed cut springs alot on older model Mustangs and have never used a spring compressor.
thanks
