Spreadsheet for anyone debating 3.73 versus 4.10 gears
I just made this. You'll see the major advantage 4.10's will provide down low versus 3.73 when upgrading from 3.55. 4.10's are the way to go on the manual. In the low RPM's, where the engine lacks torque, is where you NEED the torque multiplication of the 4.10's. 3.73 isn't enough. You'll also notice cruising RPM in 5th gear isn't as bad as people make it out to be. Attached.
I noticed using 3.55s on the 5R55S is the equivalent to having 3.73s on the TR-3650 based on the spreadsheet. I plan to stick with 3.55s with the TR-3650 for better fuel economy and a higher driveline critical vehicle speed.
Wow, thanks a lot! I'm one of them that "was" scared of 4.10's, as a matter of fact, I have a set of 3.73's in the garage waiting to go in, only because I got them so cheap. I think I'm going to get rid of them and go ahead and go with the 4.10's. The difference in RPM's isn't near as dramatic as I thought.
Again, I appreciate it!
By the way, it's not Word, it's Excel. If you don't have Microsoft Excel, click on the following link for Microsoft's Excel viewer.
http://www.microsoft.com/downloads/d...displaylang=EN
Here you go. The 5R55S worksheet is for the auto, Tr-6060 is for the GT500 (Although I didn't input the correct tire rev/mil for the GT500; 775 vs 766 isn't a big diff), and the TR-3650 is for the S197 GT.
did you ever do the 3.55 rear upgrade?
thanks!
Hi Yao,
My GT came from the factory with 3.55s, so I'm going to stick with them for now. I get 20-21 mpg in combined driving, and 24-25 mpg with a bias towards highway driving. I figure there may be a 1-2 mpg hit with 3.73s and 2-3 mpg hit with 4.10s. In retrospect I should have stuck with the 3.31s for even better gas mileage.
Rando
Aug 25, 2021 11:12 AM
Rando
Sep 30, 2015 12:28 PM
FromZto5
Sep 30, 2015 05:28 AM
