Smoke at startup
Old Mar 31, 2005 | 05:44 AM
bullittman's Avatar
I get a good puff of smoke at initial startup. It's probably just some "Leakdown" from sitting.....No smoke after car has been warmed up. I've got about 1700 miles on her. Any one else?
Old Mar 31, 2005 | 07:17 AM
lodom's Avatar
What color is the smoke?
Old Mar 31, 2005 | 07:52 AM
Jaxxon's Avatar
I noticed that if I start it up ( no smoke on initial start ), back it out of the garage and shut it off cold without letting it run for a few minutes to warm up, that on the re-start, ( say within 10 minutes or less ), it will put out some blue-ish smoke. It never does it after the engine reaches operating temperature. This follows the same pattern as my F-150's I have had, which also did the same thing. Just my observation of what I have experienced.
Jack
Old Mar 31, 2005 | 08:06 AM
bullittman's Avatar
Blue smoke.....Thanks Jack. Probably normal, I'm going to keep an eye on it.
Old Mar 31, 2005 | 08:19 AM
Kluski's Avatar
Jack
That happened to me yesterday. I pulled forward in my driveway and shut her off. Washed the car, then backed her to the original spot. The second start-up gave me that smoke-puff.
Old Mar 31, 2005 | 03:31 PM
incorrigible's Avatar
I've had this happened to me also, say three or four times. Not quite sure of the circumstances that lead up to it other than the car is cold and I might of had my foot on the gas pedal while turning her over. (bad habbit caused from my 72 Impala).
Keep an eye on it I guess. Glad to see I'm not alone.
BTW, I posted a thread on this also about one to two months back.
Old Mar 31, 2005 | 07:19 PM
05passion's Avatar
i am not an engine expert but i have been around the block and would not worry about it untill you get about 5k or 6k on it then if it still does it i would let the dealer know ,maybe just a little more breakin time
JonathonK
Which is Better
Nov 17, 2017 12:02 PM
09-gt/cs
Oct 15, 2015 10:03 AM
JonathonK
Sep 19, 2015 03:19 AM
