Should I get Non-Adjustable or Adjustable LCA's
Old Nov 29, 2006 | 11:19 PM
Jon_Purdy's Avatar
Hello everyone! I'm still learning all that there is to learn about this stuff so this may seem like a silly question to some. Should I get non-adjustable or adjustable LCA's? The car is a daily driver that will most likely never see a drag strip. Any thoughts?
Jon
Old Nov 30, 2006 | 02:15 AM
Mongoose's Avatar
Jon
Non-adjustables will work just fine.
Old Nov 30, 2006 | 11:40 AM
MaverickMLFD371's Avatar
yea, Non-Adjustables will be fine. I run them on mine as well as the Non-Adjustable UCA
Old Nov 30, 2006 | 07:36 PM
RadBOSS's Avatar
If you have lowered your car, you might consider adjustable uppers to allow for correction of the pinion angle. Don't go for solid bearings though no matter which way you go. Also for a lowered car you might want to consider the BMR LCA axle brackets and the UCA chassis bracket so you can correct the suspension linkage instant center, otherwise your car will squat alot and not launch as well ... that is the quick and dirty upgrade, there are a list of others ...
Old Nov 30, 2006 | 09:43 PM
Jon_Purdy's Avatar
I'm not sure I want to lower the car just yet. Kinda wanted to see how the handling mods I've selected (Anti-Roll Bar Kit, Strut Tower Brace, LCA's, and UCA's) do before I plump for shocks/springs.
Jon
mx5jhb
Sep 30, 2015 04:44 PM
AJ_Trevino15
Sep 28, 2015 07:51 AM
colt breaker
Sep 24, 2015 08:20 AM
DrVet
Sep 23, 2015 01:48 PM
Sep 16, 2015 06:44 PM
