Shifting points
Old May 20, 2007 | 08:21 AM
GT06stang's Avatar
Shifting points
For you 06 GT guys just courious at what RPM do you shift at.
Here is where I currently shift at
1-2: about 4k but sounds like it's really widing out
2-3 3-4 4-5 around 5k
Old May 20, 2007 | 08:52 AM
flounderlipps's Avatar
Racing @6100
Driving around 2500-3000
Old May 20, 2007 | 08:55 AM
GT06stang's Avatar
Are you running with a tune? I'm also around where you are on just driving around
Old May 20, 2007 | 09:38 AM
pville piper's Avatar
You don't say if you are running a manual or auto...
I have a manual and I usually shift between 2500 and 3500 when I am getting to highway speeds. If I want to race I will shift just below red line so I don’t bump the rev limiter… Say about 6000 rpms.
Interestingly I have been playing around with shifting and gas mileage. I have found that my gas mileage will increase about 3 mpg if I keep the rpms below 2000 when I am in town... If you don’t mind driving like a granny, it does work.
Old May 20, 2007 | 01:09 PM
Agleon's Avatar
I shift at 1500
Old May 20, 2007 | 02:16 PM
DavidM's Avatar
Based on this comment I assume you are asking about shift points when getting into it real good. If your a stick car stock with no tune to raise the rev limit then shift at around 6000 - 6100 rpm in all gears. If your an auto you dont have much choice of the shift as the computer controls it unless you get a retune. ?? Hope the info helps.
Old May 20, 2007 | 04:54 PM
Mods
Kenne Bell 2.6L @ 8 psi (Tuned by Johnny Lightning)
Diablo Tuner
Dynoed 456hp/433tq
SLP L/T with Catted X Pipe
FRPP GTA Mufflers
Detroit Tru -Trac
FRPP 3.73
PSI Steel Drive Shaft
Edelbrock Panhard Bar
Moto Blue Billet LCA
BMR Control Arm Relocation Brackets
Hellwig Rear Sway Bar
Steeda Shifter
Moto Blue Line Lock
Steeda Race Cowl Hood
Raptor Shift Light
CHE Drive Shaft Loop
18x9F 18x10R Black Bullit Wheels
275/40/18 BF Goodrich KDW rear
Old May 20, 2007 | 06:44 PM
GT06stang's Avatar
Thanks guys was just courious, I have a manual tranny and wit hthe TUNE I'm shifting at a higher RPM. I did find out that the red line rev limiter is set at 7k so I'm good to go and have some fun. And Flounderlipps thanks for posting your small mod list
Old May 20, 2007 | 07:50 PM
karman's Avatar
I didn't want to rev too high, but I don't think there is much torque over 6200rpm.
I just wanted a little more so the next gear started at a higher speed and I didn't bounce off the limiter just before I felt I wanted to shift.
Mine is set to 6500rpm, I've rarely hit it since I switched.
Old May 21, 2007 | 06:42 AM
metroplex's Avatar
For gas mileage, under 2000 RPM.
For performance, around 6000 RPM or less.
As long as you're above 4000 RPM, the car will accelerate faster. I noticed that the modular engines tend to bog a bit below 4000 RPM.
Old May 21, 2007 | 06:57 AM
Stangette's Avatar
Shifting for racing in a stock GT, around 300-400 below redline as when the clutch is engaged it will pop up another 300 and help prevent bouncing off the rev limiter. A lot of this goes on at the track. The Power Band being approx. 3400 - 5750 in the GTs;- going much beyond 5800 rpm is over revving it. The TQ tops out around 4800.
For highway acceleration, between 3k and 4.5k is plenty.
City economy driving; - shift just below 2k. Or, float the gears at 1400-1600. This involves driving like a granny and no sudden accelerations, whilst planning ahead as to what the traffic is doing.
In daily driving my 05 this way for nearly two years now, and noticing a change in the clutch last week; - upon bringing her in and being told by the Tech. that he knows I drive like a European since it is just now the clutch has set in. They were laughing at me and saying in wanting that clutch upgrade, I shall be waiting a while.
If the rev limit is changed via program in the car, and basic bolt ons with the Power Curve and TQ curve adjusted accordingly, typically the shifting will be a few hundred rpm more.
For a Stock Auto 5R55S, launching more than 1800 to just below 2000, it will bog. Torque Conv. gets in and once underway, then get into it.
Full bolt ons and the associated tuning on an Auto with a stall of 3500 will make for a nice performer.
Gigantor
May 11, 2023 07:31 PM
kponypower
Jun 17, 2020 07:17 AM
samjluck
Sep 17, 2015 10:24 PM
